tonneaucovered.com
Old 02-13-2010, 03:55 PM
01RAMTOUGH 01RAMTOUGH is offline
01RAMTOUGH is on a distinguished road
Default 01 1500 w/ 360 Magnum cranks when it want to
I got a 01 with a 360 (5.9) Mag. , sometimes when I turn the key, Nothing,.........wait a little while go back and it may crank, when I say it won't start the starter is not turning the engine over,.....I thought the ignition switch was going bad and replaced it, I have checked battery connection and changed the starter relay with the others in the fuse box, and it still does this, what else is left to check or replace, ? .....it's the only vehicle I have and really need it to be dependable again. Any and all help is appreciated.
Old 02-13-2010, 05:02 PM
Rep:2737
when it won't start, have you tried to jump start it, using another vehicle & jumper cables or a Portable Jump Starter?
Ram 1500 SLT Quad cab, 5.7 HEMI(R) , 3.55 differential, EGR bug deflector, Bushwacker fender flares, custom soft tonneau, Line_X, DEBO Step, Mag-Hytec
2016 Ram 3.0 diesel undergoing Mods G2 tonneau, Line-X, Weathertech mats, Mag-Hytec differential cover, , customized Nfab bars, CB radio, Autonet wi-fi router
Old 02-13-2010, 05:14 PM
Resident Technician
Rep:1911
Measure the voltage on the solenoid wire at the starter when it's acting up. You should be within a volt of battery voltage. If that's good and you have battery voltage on the other wire, chack for a voltage drop on the ground side. If you have than less than about .5 drop, replace the starter.
Old 02-13-2010, 05:31 PM
Yes, tried jumping it, It didn't work and the battery is about 6 months old.
Old 02-13-2010, 08:16 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Have you tried thumping on the starter when it won't start? If that wakes it up, bad starter.
Old 02-13-2010, 09:23 PM
yep, tried it , still won't start, waited about 2 hrs, it started, .......could it be the starter solenoid on the starter ?
What has me so puzzled is sometimes it does it and sometimes it don't.
Old 02-14-2010, 03:59 AM
Color: Garnet red
Rep:202
Could be. Beating on it and getting it to work means the brushes on the starter motor are bad. Beating knocks some of the crap off, but a temporary fix.
Old 02-14-2010, 11:59 AM
Could be neutral start switch , bad starter , loose or corroded connection , starter relay etc...
