Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 02-13-2010, 06:35 PM
bapple83 bapple83 is offline
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
bapple83 is on a distinguished road
Default Please Help-Electrical
I have a 1989 Dodge Ram W-250 with the 5.9L V-8.
It was running fine until a couple weeks ago when it just cut out.
I have found the reason is electrical related as the plugs aren't getting any fire. I checked the distributor but it's not getting any power either. I then replaced the ignition coil but then discovered it wasn't getting power as well.
I just don't know where to look next. Anyone who can help would be greatly appreciated.
Thanks,
Brandon Apple
Old 02-13-2010, 06:37 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
hello and welcome, i hope some one can help you, i cant being that i tend to set cars on fire when trying to repair electrical
Old 02-13-2010, 07:10 PM
Rep:1845
Have you checked the ignition switch and fuse links?
Old 10-28-2010, 02:10 AM
Ram50Man's Avatar
Ram50Man Ram50Man is offline
Vehicle: 1989 Dodge Ram 50
Trim Level: Standard
Color: Primered Black
Rep:71
Ram50Man will become famous soon enough
about the only advice i can give would be to just look around the engine compartment for any connectors that may have come undone. Then I would check all the fuses, primarily the ones under the hood, not just under the dash. Does it even attempt to turn over? Is there any power to anything else such as lights, horn, radio, etc?
**Thread resurrection! I shoulda checked the date before replying!**
'89 Dodge Ram 50: 2.0L, 5 SPD Manual, 2 WD.
