Old 02-13-2010, 09:21 PM
ntfan ntfan is offline
ntfan is on a distinguished road
Default Replacing front bearing
ok. now i've got everything removed except the bearing housing. it will NOT come off! all bolts,nuts , .But the thing will not fall off. do i just keep beating on it? thanks
Old 02-13-2010, 09:23 PM
Rep:1845
Welcome to Dodge wheel bearings! Usually a large HD puller and a big swing wrench are needed to get them out of the knuckle. Before you install the new one, remove all the rust from inside the knuckle and liberally coat it with antiseize.
Old 02-13-2010, 10:04 PM
thanks for answering... i was told that i might shove the axle in too far and damage the gears or transfer housing if i were to use a gear pully. is that a possibility?
Old 02-13-2010, 10:17 PM
Rep:1845
Never seen it happen. You're more likely to seperate the hub from the rest of the bearing first.
Old 02-14-2010, 12:59 AM
BIG hammer . Have fun . Let us know how you make out . Been there done that .
Old 02-14-2010, 02:48 PM
Default it's off
finally got the bearing off!!! only problem now is when i went to put rotor back on, i had the dust cover on backwards. but that's ok, been a experience , but from on now it's going to a real mech. thanks for the replys.....Doug
Old 02-14-2010, 02:51 PM
Rep:1845
If you cleaned out the knuckle and used antiseize, it won't be so bad if you have to do it again.
