Old 02-14-2010, 12:00 AM
StoneyWV StoneyWV is offline
Vehicle: 2010 Ram Quad Cab 4X4
Rep:27
StoneyWV is on a distinguished road
Default Proper Gearing and Highway RPM for 5.7
All,
1500 ST, 5.7, 3.55 gears, 600 miles, factory 265/70/17
Notice that at 70mph I'm only running about 1,900 rpm. Motor only stays in 4 cyl mode when perfect flat or slight descent. If I come in the gas to pass, it drops two gears without pressing hard at all. Just seems like it's a bit sluggish. What RPM is ideal for this engine at highway speeds
Did I make a mistake with 3.55's. I've always been concerned with good mpg, so didn't want to go with low gears, but wouldn't expect the factory to put gears that cause the truck to be sluggish either.
My first full size truck, so maybe I'm just not used to the feel. Please help me out here experienced full size owners.
2010 QC ST, 5.7L, 4.10 Gear Swap, 5100 Leveling Shocks at 1.7", K&N Drop-in, Pioneer U310BT, 12" Dayton/Net Audio Sub, JL Components, ARC Audio Amps, Magnaflow 14 inch, Granite Alloys sporting 34" BFG T/A KO, HID conversion full blackout.
Old 02-14-2010, 02:38 AM
dooboy's Avatar
dooboy dooboy is offline
Vehicle: 2010 ram sport crew cab 4x4
Trim Level: sport
Color: deep water blue pearl
dooboy is on a distinguished road
i drove both 3.55 and 3.93 before i decided on the 3.93 since i tow a 7000lb trailer, there is night and day difference, 3.55 was very sluggish, 3.93 gets up and go.
2010 ram sport 4x4 crew cab with every option, why not, you only live once!
