tonneaucovered.com
Old 02-14-2010, 12:12 PM
Dann's Avatar
Dann Dann is offline
Vehicle: 1998 Dodge Ram
Trim Level: SLT sport
Color: red
Rep:183
Dann has a spectacular aura aboutDann has a spectacular aura about
Default 98-01 audio wire colours (head unit)
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Behind the glove box.
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Old 02-14-2010, 12:19 PM
Resident Technician
Rep:1911
Front door speakers - 6X9"
Rear speakers - 5.25"
The optional premium speaker system features Infinity model speakers in six locations. Each of the standard front door speakers are replaced with Infinity model speakers that include integral dual 30 watt amplifiers. Each of the standard rear speakers is also replaced by an Infinity model speaker. The premium speaker system also includes an additional Infinity tweeter mounted in the A-pillar garnish molding. The total available power of the premium speaker system is about 120 watts.
Old 02-14-2010, 01:44 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
And here is what those amps look like on the front 6x9s
Old 03-01-2010, 09:44 PM
ram1500CO ram1500CO is offline
Gender: Not Specified
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
ram1500CO is on a distinguished road
Hi,
I'm new to the forum and although I've done my searching I think this is the place to ask.
I have a 99 Ram 1500 with the infinity system as described above. I am going to replace my head unit and wanted to replace the speakers as well. I noticed though that when I removed the front speakers with the custom amp on it that it was connected by a bundle of wires. How do I go about installing a new speaker with this bundle of wires I have now? Same follows for the rear speakers?
Thanks in advance for the help!
Old 02-09-2011, 09:09 PM
mitsocruiser's Avatar
mitsocruiser mitsocruiser is offline
Vehicle: 98 dodge ram
Trim Level: 2500 sport
mitsocruiser is on a distinguished road
I have the same question can I utilize any of the factory wires or should I just scrap everything and pull all new wires
Old 04-28-2012, 04:49 PM
spillage spillage is offline
Vehicle: 1998 RAM 1500 4x4 Man SWB
Trim Level: R1AZ - Sport
spillage is on a distinguished road
Since this question has been asked many times in many places, and the predominate answer seems to be "bypass", I thought I'd add to the information already provided in this, the most helpful/complete thread on the subject...
In my 1998 RAM 1500, the 6 pin speaker connector in the doors are wired as follows:
Viewing the vehicle harness connector, with the orientation lobes facing up... Left to right, Pin 1-6.
LH Door
  1. Dark Green (FL +)
  2. Violet w/Black
  3. Yellow w/Red (LH Tweeter +)
  4. Brown w/Red (FL -)
  5. Black w/Red
  6. Yellow w/Black (LH Tweeter -)
RH Door
  1. Violet (FR +)
  2. Violet w/Black
  3. Light Blue w/Red (RH Tweeter +)
  4. Blue w/Red (FR -)
  5. Black w/Red
  6. Light Blue w/Black (RH Tweeter -)
Speaker Amplifier Harness
(Both sides the same - mating pins to the above)
  1. Blue
  2. Green
  3. Yellow
  4. Brown
  5. Violet
  6. Orange
I cut the harness from the amplifiers, and joined up the wires as follows;
  • Pin 1 (Blue), Pin 3 (Yellow), New Speaker Lead +
  • Pin 4 (Brown), Pin 6 (Orange), New Speaker Lead -
Pins 2 & 5 where individually terminated... these would logically be the power supply for the old speaker amplifiers.
With a new (amplified) head unit and speakers, this wiring worked great, without hacking the standard vehicle harness.
~ Bryan ~
Old 01-11-2014, 06:02 PM
saldi saldi is offline
Vehicle: 1998.5 Dodge Ram 2500
saldi is on a distinguished road
Pins 2 & 5 where individually terminated... these would logically be the power supply for the old speaker amplifiers...
Thanks for the information Bryan. This made installing my speakers a breeze.
Adan.
Old 02-18-2014, 10:32 PM
eleeper's Avatar
eleeper eleeper is offline
Vehicle: 99 Ram 1500
Trim Level: Base
Color: Flat black
eleeper is on a distinguished road
This should help.
