Old 02-14-2010, 12:22 PM
Dann's Avatar
Dann Dann is offline
Vehicle: 1998 Dodge Ram
Trim Level: SLT sport
Color: red
Rep:183
Dann has a spectacular aura aboutDann has a spectacular aura about
Default 2005 Audio wire colours (head unit)
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Old 09-04-2010, 12:18 PM
tbihn tbihn is offline
tbihn is on a distinguished road
I just pulled the left-front door off to replace my factory speaker (which somehow had the magnet fall into the door well at some time). 2005 Dodge Ram 1500 Quad Cab with 4 speaker system. The color for the two speaker wires is green-yellow and green-? (couldn't tell exactly the second color). The color I saw for someone with an 08 had green-yellow for positive. Anyone else see this in an 05?
Old 09-05-2010, 09:31 AM
I pulled out my head unit and found that in my truck, left-front door is green-yellow for positive and green-blue for negative. Right-front door is grey-yellow for positive and grey-blue for negative. I'm wondering if the listed wiring is for a seven-speaker system.
