Old 02-14-2010, 11:26 AM
Dann's Avatar
Dann Dann is offline
Vehicle: 1998 Dodge Ram
Trim Level: SLT sport
Color: red
Rep:183
Dann has a spectacular aura aboutDann has a spectacular aura about
Default 2007 audio wire colours (head unit)
2007 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Old 02-21-2010, 10:34 PM
Coach7633's Avatar
Coach7633 Coach7633 is offline
Vehicle: 2008 Ram 1500 Big Horn
Coach7633 is on a distinguished road
Would this apply to the 2008 as well?
Old 02-22-2010, 12:34 AM
I push the skinny pedal
Rep:3283
07 & 08 should be the same. The '06s are different though.
Kurtis
Old 03-24-2010, 04:16 PM
BIGDROCH's Avatar
BIGDROCH BIGDROCH is offline
Vehicle: 2007 2500 Megacab 5.9L
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Rep:37
BIGDROCH is on a distinguished road
Notes to add...
Front Door Speakers = 6x9's w/ no tweeter
Rear Door Speakers = 6 1/2" or 6 3/4"
Dash Left and Right = 3 1/2"
Dash Center Speaker = 2 1/2"
Lots of stuff...
Old 06-30-2010, 06:30 PM
MoparLover's Avatar
MoparLover MoparLover is offline
Vehicle: 2007 Dodge Ram 1500 4x4 Hemi
Trim Level: SLT Quad Cab
MoparLover is on a distinguished road
This doesnt match what I have.. I dont have the stereo I think?
I have 2 plugs
small:
GREEN/YELLOW
GREEN/ORANGE
GREEN
big:
PINK
PINK/ORANGE
GREY/YELLOW
GREY/L BLUE
GREEN/LBLUE
GREEN/ YELLOW
BLACK/ GREEN
GREEN/ L GREEN
GREEN/GREY
GREY/GREEN
GREY L GREEN
2 GREY/RED
BLACK
Old 06-30-2010, 07:13 PM
MoparLover's Avatar
Another Problem Now.
Pulled the rear door panels and the right speaker has a grey l blue and a grey pastel green totally different. the head has 4 wires im thinking are the rear speakers grey/ d green, grey/l blue, grey/ yellow and grey green.. problem is none of the rear speakers have a grey/yellow!!! lol still scrathing my head
Old 07-01-2010, 11:36 AM
MoparLover's Avatar
Ok after a long long search on the internet I finally found the readout i was looking for. Got everything ran just need to instal and mount the amp now
Old 08-05-2010, 10:16 PM
ClownShue's Avatar
ClownShue ClownShue is offline
Vehicle: 2008 RAM
Trim Level: Regular Cab 4X4
Rep:19
ClownShue is on a distinguished road
2008 Dodge Ram 1500 Car Stereo Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: N/A
Car Radio Illumination Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Dark Green/Yellow
Left Front Speaker Negative Wire (-): Dark Green/Light Blue
Right Front Speaker Positive Wire (+): Gray/Yellow
Right Front Speaker Negative Wire (-): Gray/Light Blue
Left Rear Speaker Positive Wire (+): Gray/Light Green
Left Rear Speaker Negative Wire (-): Gray/Dark Green
Right Rear Speaker Positive Wire (+): Dark Green/Gray
Right Rear Speaker Negative Wire (-): Dark Green/Light Green
source: modifiedlife.com/2008-dodge-ram-1500-car-stereo-install-instructions/
Old 10-01-2010, 10:38 AM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
maby a admin can come in a make it all into one list?
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 10-18-2010, 10:38 AM
superted's Avatar
superted superted is offline
Rep:32
superted is on a distinguished road
Ok, so I have posted this before but.... I have followed the factory wiring color code here, checked my connections, and am now getting an AWEFUL cracking coming out of the Right Front speaker. What gives?
