Manual shifting question? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 02-15-2010, 12:45 AM
Ray's Avatar
Ray Ray is offline
Vehicle: 2017 Dodge Ram 1500 Crew Cab
Color: Bright metallic silver
Rep:45
Ray is on a distinguished road
Default Manual shifting question?
I have the 2010 Ram 1500 sport. I noticed when using the manual shift, the transer from 2nd gear to 3rd gear is kind of sluggish and has a lag. I tried shifting into 3rd gear at differnt speeds and rpm's and still got the same results. Every other gear seem to have a nice hard shift when I use the shifter manually. Plus when I just keep it in drive and don't shift manually all the gears seem to shift fine. Anybody else notice this or am I doing something wrong when shifting manually
Old 02-15-2010, 12:48 AM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:435
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
I haven't messed around with the manual shift too much on my truck. Could it be that you are shifting too soon at a low rpm? It's the only thing I can think of.
Old 02-15-2010, 12:54 AM
Ray's Avatar
Ray Ray is offline
Rep:45
I thought that as well, but I have tried revving out 2nd gear before shifting into third and still experinced a lag shift
Old 02-15-2010, 02:01 PM
MotorCityRam's Avatar
MotorCityRam MotorCityRam is offline
Vehicle: 2010 Ram QC 4x2
Color: Inferno Red
Rep:23
MotorCityRam is on a distinguished road
I've heard aftermarket flash tuners can help with this but I've never owned a late model automatic w/ man shift (regardless of make) that shifted quickly in manual mode.
Sean M
2010 Quad Cap Sport 4x2 / Inferno Red / HEMI / 3.92s / leather / Truxedo Truxsport tonneau
Old 02-15-2010, 05:01 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:86
topgun will become famous soon enough
You do realize that when you are in ERS mode (manual), the gear pattern used is different? ERS or Tow Haul enables the extra underdrive gear. So it uses the one labeled "2nd Prime" when shifting. It will say 3 on the dash but 2nd Prime is actually what you are in. 4 is actually 3rd and finally 5 is actually 4th, the max gear you can be in in that mode.
Below you can see the ratio difference from 2nd to 2nd Prime is not that great so the shift will feel really strange. Almost like it didn't shift. I'd just about guarantee that is what you are feeling. If left in Auto, this gear is not used unless you downshift such as to pass. So it will skip that gear and shift directly to 3rd causing the tranny to feel a lot different.
This shifting setup is far from a manual even when in ERS mode. It just limits the max gear you can be in.
Sounds crazy but that is the way it works. It's all spelled out in your owners manual.
1st-3.00:1
2nd-1.67:1
2nd Prime-1.50:1
3rd-1.00:1
4th-0.75:1
5th-0.67:1
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Husky X-Act Contour Floor Mats, Cooper AT3 285/70/R17's, Moroso Catch Can
Old 02-15-2010, 05:37 PM
Ray's Avatar
Ray Ray is offline
Rep:45
Thx topgun, that was a great explanation and makes sense. The way you described it was what I was feeling. I am just glad that it's normal and there is nothing wrong with my tranny
Old 03-12-2010, 12:43 PM
HEMICOWBOY HEMICOWBOY is offline
HEMICOWBOY is on a distinguished road
Default manual shifting
I heard they changed the 5th gear ratio from .67 to .50 in 2009. can anybody confirm this.
