Transmission trouble with diesel engines? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 02-15-2010, 08:37 PM
mechanixman mechanixman is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
mechanixman is on a distinguished road
Question Transmission trouble with diesel engines?
Hello all... I am a newbie to Dodge truck, looking to buy my first. I have had Chevrolet trucks for years and have become bored with their design. I have always like the looks of the Dodge trucks, but have stayed away because I have heard nothing but bad things about transmissions.
I am looking at either 2500 or 3500 diesel, year range 2003 - 2006
So here are my questions.
For all you guys with the diesels, what kind of transmission troubles have you had?
espically anyone who has the aftermarket power programer, or aftermarket intakes and intercoolers.
what things do I need to look for when I am out looking for my new truck? common failures?
What power programer has the best reputation for Dodge diesels?
What is a DPF delete?
Thank you for your help,
-Jeff
Old 02-15-2010, 09:08 PM
will's Avatar
will will is offline
Vehicle: 2010 dodge ram quad cab
Trim Level: slt/bighorn
Color: silver
Rep:43
will is on a distinguished road
A simple google search would help alot. Go to the newbie section and let everyone know your here. As far as I know, they are pretty solid unless you get around 1000lbs of tourque. Then a little beefing up is needed.
a DPF delete is a diesel particulate filter delete. replace with a straight pipe
OLD TRUCK
NEW truck soon to be here
Old 02-15-2010, 09:10 PM
iRESQu iRESQu is offline
Rep:2217
Welcome Mechanixman. I have an 08' 2500 6.7l with a Bully Dog and nothing more. I do not run my programmer/tuner on Extreme because there are other recommended components that I haven't obtained yet. I set it on performance and I do not romp it.
I have only had the tuner about a couple of weeks.
I hope this helped at least a little.
Old 02-15-2010, 09:25 PM
Resident Technician
Rep:1915
The transmission problems you're referring to are the older with 46/47RE transmissions which were last used in '03 or '04. The 48RE used behind the 5.9 is a much more durable unit. Personally, my favorite is the '06.
