Old 02-16-2010, 04:21 PM
Silver05Ram's Avatar
Silver05Ram Silver05Ram is offline
Vehicle: 2005 Dodge Ram
Rep:98
Silver05Ram will become famous soon enough
Default Suggestion on my new shocks?
I am going to buy new shocks for my 05 2wd ram. Are there any shocks I can get that will lift the front end up a few inches? What are the pros and cons of stiff and soft shocks? Which brand would you reccomend? Thanks, I'm really trying to get some lift out of these new shocks.
35" Mickey Thompson ATZ's/stock 20's painted black. Tinted Tails. Dynomax Bullet Resonator. LED's inside cab. Debadged. 12k Hid's
Old 02-16-2010, 05:12 PM
reider's Avatar
reider reider is offline
Vehicle: 01 half ton dodge 5 speed
Color: burgandy
Rep:87
reider will become famous soon enough
shocks wont lift your truck, if you want a little lift, get a spacer.
3" body35x13.5toyom/t's 15x10wheels flwmster40 hella500lights pwerbass400wamp pwerbass10" kicker6x9s
Old 02-16-2010, 05:18 PM
Shocks are an absorber .
Old 02-16-2010, 07:28 PM
ScatPak07's Avatar
Rep:970
Hey man. If you want to raise your truck in the front a couple inches then i recommend getting a spacer. If you do want to replace your shocks then look at Ranchero, they have a strut/shock that also lift the truck in the front a coupel inches. You can get a set of shocks from them in the back as well. i have heard good things about them, take a look.
If you just want to get a spacer you can look at Daystar and maybe Bilstein for shocks. Thats what i am going to do. i have the Daystar and now I'm looking at some Bilsteins for the shocks front and rear
Old 02-16-2010, 07:47 PM
ilovetards ilovetards is offline
Vehicle: 1998 Dodge Ram 5.9L
Trim Level: SLT Laramie
ilovetards is on a distinguished road
The spacer is usually the cheapest way to level the front end as everyone has stated. I'm curious though why you are going to lift it? I can understand the spacer for looks, but why a lift on a 2wd. Not trying to start anything, just wondering.
Old 02-16-2010, 07:57 PM
Rep:98
I plan on getting Daystar spacers, but I need to replace my shocks and if I can, I would like to get a couple inches out of them. It may be 2wd but I'm not taking it rock-climbing or driving through ponds so my 2wd is plenty for me. I need the extra few inches of clearance so I can stop dragging my bumpers when I'm driving to the duck hunting spots or driving to the deer stand. I mean if you're willing to give me the $$ for the 4wd conversion I'll happily take it :] lol.
Old 02-16-2010, 08:00 PM
Rep:98
Yeah I have been looking at Daystar for a spacer but they only have 1 inch and 1.5 inch for my truck. Would you recommend putting two 1.5 inch on for a combined 3 inches? Explain how the shock/strut combo will lift it a couple of inches. I'm new to the suspension side of the world. My guess was that if I got longer/stiffer shocks they would push me up a little higher and have less "sag" if you will.
Old 02-16-2010, 08:09 PM
ScatPak07's Avatar
Rep:970
I will post the link to Rancho so you can see this set up. I think you will be happy with this since you want to get new shocks anyway. It makes more sense to do this then to get spacers and shocks instead of an all in one set up
http://www.gorancho.com/products/shocks/quicklift.php
Link to Moes Performance so I'm not bashing our supporters : http://moesperformance.com/index.php...oducts_id=9160
Rancho Quicklift suspension lift systems are easy-to-install solutions that raise the front suspension and improve ride quality. Quicklift systems provide an aggressive vehicle stance and offer the option of adding larger tire and wheel packages. Rancho Quicklift systems use Rancho's My-Ride 9-position ride tuning struts and shock absorbers and are designed to reuse the original equipment coil springs.
Old 02-16-2010, 08:25 PM
Rep:98
Thanks. What do you have on your truck? Will the Rancho combo work with a 2wd?
Old 02-16-2010, 08:36 PM
reider's Avatar
Color: burgandy
Rep:87
topguncustomz.com, ive said it before i'll say it again, 90 bucks for 3 inch STEEL spacers, metal spacers is the way to go.
bilstein, leveling shocks, new shocks, stiff
