Old 02-16-2010, 09:50 PM
ScatPak07's Avatar
Rep:970
Yea Reider he wants to get new shocks anyways. So i showed him a setup that will give him a lift and shocks.
I have the Daystar lift kit 2.5". I want to get the Bilstein 5100 shocks front and rear. I don't know if you want to do that as well or get the Rancho lift. I think the Rancho shocks would be good. I think you should look at the price and decide with that.
You question about stacking spacer, I don't think hats a good idea. They may shift or something like that. Same goes for blocks they shouldn't be stacked.
Old 02-16-2010, 10:38 PM
reider's Avatar
reider reider is offline
Vehicle: 01 half ton dodge 5 speed
Color: burgandy
Rep:87
reider will become famous soon enough
i believe its still cheaper to piece it together with the 3 inch spacers from topguncustomz and if he wants an add a leaf from jcwhitney for 50 bucks, but with a 2 wheel drive i dont know that you would need an add a leaf because the back already sits higher than the front, and then for the basic rancho shocks you can get those just about anywhere for pretty cheap, so 90 for the spacer, 50 for add a leaf if needed, and about 30 bucks or less for the basic rancho shocks- so yer looking at $210 w/o add a leaf, and $260 with add a leaf, plus of course shipping. and for the shocks if you shop around a little im sure you can find the ranchos for cheap.
3" body35x13.5toyom/t's 15x10wheels flwmster40 hella500lights pwerbass400wamp pwerbass10" kicker6x9s
Old 02-17-2010, 07:10 PM
Silver05Ram's Avatar
Silver05Ram Silver05Ram is offline
Vehicle: 2005 Dodge Ram
Rep:98
Silver05Ram will become famous soon enough
Originally Posted by reider View Post
topguncustomz.com, ive said it before i'll say it again, 90 bucks for 3 inch STEEL spacers, metal spacers is the way to go.
I've looked up the spacers on topguncustomz.com and all they have is 1 and 1.5 inchs. Where do you see the 3 inch? Thats exactly what I want. Does it matter what band vehicle I order it from. Like can I get a 3 inch spacer for a ford and use it on my dodge?
35" Mickey Thompson ATZ's/stock 20's painted black. Tinted Tails. Dynomax Bullet Resonator. LED's inside cab. Debadged. 12k Hid's
Old 02-17-2010, 07:31 PM
reider's Avatar
Color: burgandy
Rep:87
i know its in there, i couldnt tell you on the ford thing, i think if they were the same diameter and same mounting i think it would be ok, but ive never done that.
http://www.topguncustomz.com/Store/G...view=191687046
89.95.
i just read on topguncustomz that those spacers wont fit 2wd, so i apologize for mis-information, but i know there are still ways to get a small lift without spending a lot of money. just do a little research.
Old 02-18-2010, 11:41 AM
canuckboy's Avatar
canuckboy canuckboy is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: None
Rep:114
canuckboy will become famous soon enoughcanuckboy will become famous soon enough
If you need new shocks and want more height I say spend the money if you can and buy a full suspension lift kit. A 3 to 4 inch suspension lift would be plenty for a 2WD.
Im just saying if your going to go and buy new front shocks and spacers then just take that money and buy a complete suspension kit and have it done with. Then you dont have to worry about replacing the other parts that you didnt do in the first place. Say you replace just the front shocks but the rears are 5 years old. Now say in 5 years your rears go and you replace them. Well now your fronts are 5 years old and the sets will never be new together. Freshen up everything together and you will be happy. Do half and it will be never ending.
I see you have a lift kit in the mail.... is that still a go ??
Old 02-18-2010, 02:41 PM
reider's Avatar
Color: burgandy
Rep:87
why spend all that money on stuff you dont necessarily need? all you need are spacers and maybe an add a leaf, and shocks, if the old ones are worn out. why spend 500-600 for a lift that small? when you can just piece it together for less than half of that? there are a lot of ways to lift a vehicle, you dont always need to throw a big chunk of change down on an out of the box lift kit, when you can do a little research and piece on together for less money, maybe money is no object for some people, but as for me and most others, saving money and still being able to do it right is a good way to go. but, do what ever floats your boat.
Old 02-18-2010, 04:00 PM
txhemi's Avatar
txhemi txhemi is offline
Vehicle: 2008 Quad Cab 1500 2WD
Trim Level: SLT Lone Star
Color: Mineral Gray
Rep:268
txhemi is a jewel in the roughtxhemi is a jewel in the roughtxhemi is a jewel in the rough
I bought 3 inch lift Rough Country spindles from ebay for like $200 used on my 2wd and I love it. Once I wear out my tires, I'll be adding the Daystar spacers that are sitting in my toolbox, new shocks all the way around, and bumping the rear end up to the last notch on my lift shackles. I don't do any puddling jumping but the extra ground clearance is nice.
Old 02-18-2010, 04:20 PM
Rep:2890
someone may have mentioned this
Dodge Ram 2002-2005 1500 2wd part #66-1050 at AutoAnything $225.95
http://www.autoanything.com/suspensi...A2931A0A0.aspx
oops, its for 4 wheel drive
Old 02-18-2010, 07:45 PM
Rep:98
Quick question, Could I put two 1 1/2 inch spacers in the front for a combined 3 inches? I'm trying to get like 4-6 inches in the front so I can block the back and it sit somewhat level still
Old 02-18-2010, 07:49 PM
ScatPak07's Avatar
Rep:970
I would not recommend that man. I know your not suppposed to stack blocks so I wouldn't stack the spacers.
3" lift you will need to do the whole suspension. 2" is the most your going to get from spacers maybe 2.5". I really think to meet your expectations your going to need a suspension kit
bilstein, leveling shocks, new shocks, stiff
