United Radio
Old 02-16-2010, 10:54 AM
zzz zzz is offline
Vehicle: 2000 dodge ram 2500
Color: green
zzz is on a distinguished road
Default No bus
I have a 2000 dodge 2500 ram 5.9l v8 and last thursday the trucks gauges went out, would not start, and odom flashed then read no bus. All the fuses were good fuel pump not turning on. Engine cranks just wont fire. Read all over and heard from crank sensor to bad conections. Had all checked so today I will order a new pcm. Is this my problem???? Cant pull codes no bus
Old 02-16-2010, 10:58 AM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
Old 02-16-2010, 10:59 AM
Rep:1845
Have it scanned with a scan tool before you go spending money on a PCM. You could have an ASD relay or related wiring problem.
Old 02-16-2010, 11:54 AM
zzz zzz is offline
Color: green
No scan tool would work, dealer said to bring it in. But the towing fees would be an arm leg and its miles from the dealer. There was power to the ads. My truck went down on me about 75 miles from home. And talk about luck I took my wife honda up there saturday and it quit on me. And then yesterday uncle was taken me up there and it to went down! Fixed both costen me $ to get three rides goen. Should have got it towed but the dealer labor fees ouch. But my trucks my baby i need her! thanks Remerson228 all check more in the ads
Old 02-16-2010, 12:08 PM
iRESQu iRESQu is offline
Rep:2217
I got a "no bus" code once too and although I don't know what it means, it was while I was putting a....er.....um.........mod on my truck. We'll leave it at that!
Old 02-16-2010, 12:17 PM
zzz zzz is offline
Color: green
Yea every time I upgrade my truck she fights me, she dont like change, shes hard. But dont know what to about no bus on the odom.
Old 02-16-2010, 12:20 PM
Rep:2217
Randy, what is a "no bus" code exactly? If you don't mind me asking. Should we be concerned when we get those?
Old 02-16-2010, 04:23 PM
rustyolred's Avatar
rustyolred rustyolred is offline
Vehicle: 1997 Ram 1500 ext cab 4x4
Trim Level: Laramie SLT
Rep:20
rustyolred is on a distinguished road
Send a message via AIM to rustyolred
Do some reading here. It should help.
http://www.faqs.org/qa/qa-12673.html
Old 02-20-2010, 01:34 AM
zzz zzz is offline
Color: green
Solved my no bus problem, the ecm was fired put the new on and she fired up. The old cover to the ecm was all dirty. I unscrewed the old one, had a jelly covering the electronics guess to keep it cool. On the top the jelly was cracked. And the inside looked like the out. Also I could see were water ran down on the inside cause some parts was clean. Good to be back on the road. Next I'm going to get a spal fan kit put in.
Old 02-20-2010, 01:45 AM
zzz zzz is offline
Color: green
Also forgot to thank Remerson228 and Rustyolred for the info we checked and double checked all the info that you two posted. That left only the ecm. Thank you this a good Ram site!!!!!!!!!!!!
