Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel > Exhaust
Exhaust Cummins Diesel Exhaust Discussion
Old 02-20-2010, 01:55 AM
DigzDodge07's Avatar
DigzDodge07 DigzDodge07 is offline
Vehicle: 2007 DodgeRam 2500HD4X4
Rep:48
DigzDodge07 is on a distinguished road
Default New Exhaust 6.7
Will it make a difference to take the Exhaust from the last pod off and straight pipe it out large?
Old 02-23-2010, 07:49 PM
Smokin'Ram Smokin'Ram is offline
Vehicle: 2002 Ram 2500 CTD
Trim Level: SLT quad cab
Color: silver
Rep:12
Smokin'Ram is on a distinguished road
Diesel Power Magazine did a build up of a stock 6.7L. They went from the particulate filter back with straight 5" exhaust and said that it offered a little better milage and lowered EGT's but it wasnt much louder than stock.
I dont recall if there was any HP increase but im sure its serveral hundred $ for the system and if you dont have a programmer or other performance parts that would require the motor to have larger exhaust then you need to decide if its worth the money...
I have a Banks 4" system and i like the sound plus my stock exhaust fell off so i figured might as well go bigger.
Old 09-29-2010, 10:19 PM
lancinator lancinator is offline
lancinator is on a distinguished road
Good luck with your exhaust. I took all the DPF and cat and muffler off. I made an exhaust flange and put in a piece of 4" where i removed everything else. The exhaust temps are much lower and the sound is just a tiny bit louder. I really can't tell you if going 5" will help you or not. I know that my exhaust feels like it has a lot more air coming out of it now.
Old 07-03-2011, 07:44 PM
Dooner's Avatar
Dooner Dooner is offline
Vehicle: 2010 Dodge Ram 3500 DRW 2wd
Color: PDA-Light Greystone Pearl
Rep:20
Dooner is on a distinguished road
I think I read in one of the recent Diesel ??????????? magazines, that going with a larger straight pipe had decreased some of the lower rpm range torque. When I get back home, I will have to try and find that and see if I am remembering right.
Dooner
2010 Dodge Ram 3500 DRW 2wd and 1964 Plymouth Belvedere 4dr Sedan
