Old 02-20-2010, 09:29 AM
Magmania's Avatar
Magmania Magmania is offline
Vehicle: 2007 Ram 1500 Quad Cab (5.7L)
Trim Level: SLT Big Horn Edition
Rep:60
Magmania will become famous soon enough
Question Sirius Satelite Radio Question
We purchased our previously owned 2007 Quad Cab this week and just yesterday we tried to activate our Sirius account and radio.
Spoke with a Sirius rep and was able to open and create an account but for whatever reason the radio was unable to receive the activation signal.
After 2 seperate and unsuccessful attempts to activate the radio the rep connected me with someone from "Tech Support".
The only thing that he asked me to try was to shut off the radio and engine and open my drivers side door for 45 seconds. He said this was equivalent to a soft reset.
Still unable to activate the radio tho and that's all he had to offer.
Do any of you guys or gals have any idea of what I might check for?
Has anyone ever expienced this and gotten past it?
Everything on my Single CD, AM/FM factory radio works fine.
Maybe the antenna connection? I haven't ripped the radio out yet to see if it is connected but I will attempt that once I figure out how to get the bezel off.
Thank you all for any and all input.
Dave.
Old 02-20-2010, 09:35 AM
Rep:1909
You should have the truck scanned for any radio related codes and to make sure everything is communicating properly on the CAN B bus network before tearing into the dash.
Old 02-20-2010, 09:39 AM
Magmania's Avatar
Rep:60
Sounds like good advice. Not really wanting to go inside this soon into ownership yet.
We are taking it in to get the running boards installed so I will see if I can get that taken care of as well.
Thank you.
Old 02-20-2010, 10:45 AM
Try a battery disconnect. Pull the negative cable, wait a few minutes, reconnect and see if your sat works then. The downside to this process is any pre-set features (door auto lock at speed, auto up or down windows, etc...) will also reset.
Lastly, make sure you have the correct SAR number for your system. On my Chrysler it's determined by a series of EVIC displays and button pushing. Check your manual for the process to get it, write down the number, then try the activation process again.
Old 02-20-2010, 11:16 AM
beermanjoe's Avatar
beermanjoe beermanjoe is offline
Vehicle: 2007 Ram
Rep:25
beermanjoe is on a distinguished road
Your sat radio should get one weather channel even if it`s not activated. I think it`s like channel 184 or 188.If that`s coming in.You don`t have an antenna issue.
Old 02-20-2010, 11:20 AM
SilverMaggie's Avatar
SilverMaggie SilverMaggie is offline
Vehicle: 2007 Dodge Ram 1500
Rep:81
SilverMaggie will become famous soon enough
184 comes up on the screen, but we hear nothing, and that channel won't change, volume won't go up or down.
[CENTER][SIGPIC][/SIGPIC][/CENTER]
Old 02-20-2010, 11:21 AM
Channel 184 is the default. You sure the activation is complete???
I had a hell of a time with mine on the Chrysler...LOL
Old 02-20-2010, 11:24 AM
Rep:81
We never got to the point where activation could be completed, that's the problem. They sent out the signal 3 times and our radio never got the activation signal.
Old 02-20-2010, 11:28 AM
So let me ask this...did you get your SAR number (that's the receiver ID) before you started the activation?
That seemed to be key to the activation.
SATELLITE RADIO — IF EQUIPPED
Satellite radio uses direct satellite to receiver broadcasting
technology to provide clear digital sound, coast to
coast. The subscription service provider is Sirius™ Satellite
Radio. This service offers up to 100 channels of music,
sports, news, entertainment, and programming for children,
directly from its satellites and broadcasting studios.
System Activation
To activate your Sirius Satellite Radio service, call the
toll-free number 888-539-7474, or visit the Sirius web site
at www.sirius.com. Please have the following information
available when activating your system:
1. The Electronic Serial Number/Sirius Identification
Number (ESN/SID).
2. Credit card information.
3. Your Vehicle Identification Number.
Number (ESN/SID)
The Electronic Serial Number/Sirius Identification Number
is needed to activate your Sirius Satellite Radio
system. To access the ESN/SID, refer to the following
steps:
ESN/SID Access With REF Radios
With the ignition switch in the ACCESSORY position and
the radio OFF, press the CD Eject and Time buttons
simultaneously for 3 seconds. The first four digits of the
twelve-digit ESN/SID number will be displayed. Press
the SEEK UP button to display the next four digits.
Continue to press the SEEK UP button until all twelve
ESN/SID digits have been displayed. The SEEK DOWN
will page down until the first four digits are displayed.
The radio will exit the ESN/SID mode when any other
button is pushed, the ignition is turned OFF, or 5 minutes
has passed since any button was pushed.
ESN/SID Access With RAK Radio
the radio OFF, press the CD Eject and TIME buttons
UNDERSTANDING YOUR INSTRUMENT PANEL 165
simultaneously for 3 seconds. All twelve ESN/SID numbers
will be displayed. The radio will exit the ESN/SID
mode when any other button is pushed, the ignition is
turned OFF, or 5 minutes has passed since any button
was pushed.
ESN/SID Access With Navigation Radios
Please refer to your Navigation User’s Manual.
Old 02-20-2010, 11:41 AM
Magmania's Avatar
Rep:60
Hello Micheal.
We went through all of those steps.
We were able to pull up the ESN/SID number via the above directions.
We called Sirius and opened an account. The final step to activate the radio was "them" (Sirius) sending out an activation signal that would send an activation notice to our radio display stating that the activation is complete.
That message is not getting to the radio. They sent out the signal at least 3 different times and they said maybe I was in a bad area and the signal was getting interfered with.
We have since driven and changed locations many times and still no activation.
Their answer at this point is that we should go and see the dealership and have them look at it.
