Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
ZDOG
Old 02-20-2010, 11:10 AM
OTwoRam's Avatar
OTwoRam OTwoRam is offline
Vehicle: 2002 Dodge Ram Slt
Color: Charcoal
Rep:120
OTwoRam will become famous soon enoughOTwoRam will become famous soon enough
Default Coolant Issues on the 4.7
I am loosing coolant for some reason. I have 2002 1500 4.7 with 40k on it. It smells as if it is leaking somewhere on the top/passenger side of the motor but I cant see anything leaking. Someone told me that the 4.7 had issues with the plastic intake manifold cracking but I didnt know for sure.
Old 02-20-2010, 11:49 AM
DigzDodge07's Avatar
DigzDodge07 DigzDodge07 is offline
Vehicle: 2007 DodgeRam 2500HD4X4
Rep:48
DigzDodge07 is on a distinguished road
Mine was a split on the plastic cap, on the seem, on the side passenger sideof the radiator!
Old 02-20-2010, 02:41 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
That intake manifold doesn't have water running through it.
If water tracks aren't obvious you might want to do a dye test. Most likely culprits probably going to be water pump/radiator/hose/head gasket problem.
My 4.7 had developed a corrosion channel in the head between #1 cyl and a water jacket causing coolant loss. Do you have steam coming from the exhaust?
Old 02-20-2010, 07:20 PM
OTwoRam's Avatar
Color: Charcoal
Rep:120
no there isnt. I doesn't seem to be burning it, there is just a smell of coolant on the passenger side when I stick my head in the wheel well. And every so often I look at the res tank and it is almost empty
Old 02-20-2010, 08:49 PM
Resident Technician
Rep:1911
Sounds like it's time to pressure test the system and cap.
Old 02-20-2010, 09:59 PM
streetbob streetbob is offline
Vehicle: 2002 Ram 1500
Rep:28
streetbob is on a distinguished road
Ya, mine used coolant too. Periodically it would push some out of the over flow. The dealer installed a new 18lb cap and told that fixed it.... till it hydroliced on the number three cylinder. The head had a crack from the water jacket to the cylinder and another one starting back toward #5. I've had the truck since new, never overheated it. It apparently was seeping for years until that fatal day.
Old 02-20-2010, 10:29 PM
I just threw away a pair of perfectly good 4.7 heads 6 months ago after I closed down my shop .
Old 02-21-2010, 08:19 AM
OTwoRam's Avatar
Color: Charcoal
Rep:120
tom what was your shop called? I used to live in dundalk
Old 02-21-2010, 02:30 PM
My shop was in Hanover , Md. by Arundel Mills .
Old 02-21-2010, 06:17 PM
Rep:28
To bad you tossed them. I couldn't find anything for under 700.00 and they were as much as 1200.00. I had to have one shipped from a shop in Oregon. My truck acts totally different now and some of the things it did, it doesn't do any more. This makes me happy.
