Old 02-20-2010, 01:42 PM
06hemiramm 06hemiramm is offline
06hemiramm is on a distinguished road
Default Nitto 33's on stock 17s?
ive got a 2006 1500 4wd standard cab ram. i need new tires and dont want 245s on it anymore, they look tiny. i want a mud tire, and im thinking the nitto mud grapplers. i dont have the money for new wheels as the tires will be about 1000 bucks. so, my questions is, can i put 33 12.50 r17s on my stock wheels and not rub? my 2" leveling kit will go on at the same time as my tires. my stock wheels are the 17 inch five spoke wheels, i think they are 17x8 or 9, not sure which. ill be doing this next week so any help would be great! thanks guys!
Old 02-20-2010, 03:00 PM
hauser775's Avatar
hauser775 hauser775 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SLT Laramie
Rep:67
hauser775 will become famous soon enough
based on other threads that set up will work without rubbing
Old 02-20-2010, 05:48 PM
ScatPak07's Avatar
Rep:970
You will be fine with 33s on your truck. If you get the spacer alone they say you can put up to a 35. i have a 2.5"lift with 33s and I have no rubbing. 305/55/20 are the size I have on my stick 20s
Old 02-21-2010, 12:32 AM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
i have a 2 1/2 level kit on mine with 34-12.50-17 (305-70-17) with no rubbing!
you will have to have a 1/4" spacer if using the factory wheels!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 02-21-2010, 08:32 PM
Silver05Ram's Avatar
Silver05Ram Silver05Ram is offline
Vehicle: 2005 Dodge Ram
Rep:98
Silver05Ram will become famous soon enough
I got Nitto 285/70r17s (basically a 33") on my 2wd ram (2005) with the 17 inch rims. I have no lift or level at all and I don't rub
35" Mickey Thompson ATZ's/stock 20's painted black. Tinted Tails. Dynomax Bullet Resonator. LED's inside cab. Debadged. 12k Hid's
Old 02-22-2010, 04:10 PM
silver05, do you have spacers? it seems like some need the spacers some dont??
Old 02-25-2010, 02:55 PM
bigC310's Avatar
bigC310 bigC310 is offline
Vehicle: 2005 dodge ram 1500
Rep:105
bigC310 will become famous soon enoughbigC310 will become famous soon enough
na you dont need any spacers you will be fine im runnin the same thing but it is an 05 and i have had no problem at all
Old 02-25-2010, 03:00 PM
Rep:2657
if you have to use spacers, do you need longer studs?
i'm just curious
Old 02-25-2010, 03:06 PM
txhemi's Avatar
txhemi txhemi is offline
Vehicle: 2008 Quad Cab 1500 2WD
Trim Level: SLT Lone Star
Color: Mineral Gray
Rep:268
txhemi is a jewel in the roughtxhemi is a jewel in the roughtxhemi is a jewel in the rough
I had 285/70/17 on my stock '04 2wd with no rubbing.
Old 02-25-2010, 03:44 PM
jkulysses jkulysses is offline
Vehicle: 2007 Ram Quad Cab
Trim Level: 2500 4x4 HEMI
Rep:68
jkulysses will become famous soon enough
That's because 285/70/17 is basically a 33x11.50 tire and from what I've read the 12.50 and up wide tires are the ones that require spacers or different wheels.
