Old 02-20-2010, 02:34 PM
cope1980 cope1980 is offline
Vehicle: 1999 RAm 1500 4x4
Trim Level: Sport pkg
Color: Blue
cope1980 is on a distinguished road
Default Oil loss/coolant
First off, I want to say hellow from Southeast Missouri! And Thanks in advance for this site!
I am not a mechanic (unless shade tree counts). I am forced to do my own repairs because of tight budget.
Ok, I have a 99 Ram 4x4 Sport with 5.9 and 174k milage. I have noticed a white film on my oil fill cap. Also I use oil like crazy (no smoke at all). I have tried to gather as much info as possible before doing anything so here is what I know. Cyl 3 4 and 8 55-60 lbs compression. Rest of cyl 100-120 compression. 20" of vacuum. Have not done a leak down test. Am I looking at just a manifold problem or worse?
Again, thanks for helping.
Old 02-20-2010, 02:56 PM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
Welcome to the forum! I don't have the technical knowledge to help you but you will get some help soon from some of the wiser members.
Old 02-20-2010, 03:14 PM
Color: Blue
Ok, a little more info, thanks to a post I found on here.
I just went out and pulled the air cleaner and looked in the throttle body. I can see an oil film inside and maybe a small amount of sludge (some kind of crap) inside. Also the same milky oil/coolant in the pcv valve and hose.
I am pretty sure the intake manifold gasket is gone, but the compression has me bothered. I do not have the funds for a total rebuild so I have to "just fix what is broke".
Old 02-20-2010, 06:08 PM
Rep:2657
welcome to the forum
this may help you sort it out a bit
http://www.aa1car.com/library/compression.htm
Old 02-20-2010, 07:51 PM
Rep:1890
You should perform a leakdown test to see where it's going. Sounds like you may wind up pulling both heads off though.
Old 02-20-2010, 08:07 PM
Color: Blue
On the leak down test, I have read about it, but not sure how to do it, and no one around my area has one. We are very "back woods" here.
Old 02-20-2010, 09:08 PM
How did the plugs look that came out of the 2 low compression holes ? Really once you have the intake off it's not a whole lot more work to pull the heads . But you need to know if the rings are ok . Thats where a leak down test comes in .
Old 02-20-2010, 09:25 PM
Color: Blue
All the plugs looked normal. I replaced all of them when I did the compression test. I could not tell a difference between them.
Can I build a leak down tester? No one here really even knows what I am talking about. Autozone said "a what"?
I have an air compressor at work and also compressed dry nitrogen.
Old 02-20-2010, 10:44 PM
Heres a leak down tester kit that I found on Google shopping . http://www.google.com/products?q=lea...TF-8&scoring=p
Old 02-21-2010, 12:01 AM
ScatPak07's Avatar
Rep:970
Well seems like you got the help you need. So all I'm going to say is goodluck with the fix! I hope it comes out better then new!!
