Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 02-20-2010, 03:00 PM
cableguy493 cableguy493 is offline
Vehicle: 04 1500 4x4 4.7l v8
cableguy493 is on a distinguished road
Default HELP!!!! Having brake issues....what should i check?
The wife was drving my truck when she called and said it wouldn't move and was smoking from both front wheel wells. I showed up and found extreme pressure on the brake pedal and the smell of burnt pads. I tried releasing pressure from both front bleeder valves with no results. The brake pedal pressure finally released on its own and I was able to baby it home. Not sure if my calipers are the problem or something else. Was told it could be the power brake booster....how do i test it to see if its bad?
Old 02-20-2010, 03:09 PM
ScatPak07's Avatar
Rep:970
Hmmm seems like you have a problem haha. I wish I knew what it could be to help you out. That caliper seems like a good place to start. I wish I was more knowledgable in this but I'll let someone else take it from here
Old 02-20-2010, 03:20 PM
Rep:2657
its hard to answer your question without more information, like year, make, model,
you could type it in here, OR better yet, fill in the USER CP info, then it will be displayed for us to see automatically, every time that you post
Old 02-21-2010, 04:23 PM
Sorry, guess the info would be a little more useful.
04 1500 4.7L 4x4
Old 02-21-2010, 04:38 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
If you open the bleeders and the caliper still did not release, I would lean toward the calipers. Although it is odd that both would go out at exactly the same time. Have you pulled them off yet and tried to reset the pistons?
Old 02-21-2010, 05:01 PM
Its driveable now, whatever was keeping the brakes locked released on its own. I drove it from where it happened at back to the house which is about 6 miles. I drove again today about 5 miles round trip and it seems to be ok, i just dont want it to happen again. I need it ready for a road trip in the weeks to come.
Old 02-21-2010, 07:22 PM
Color: Garnet red
Rep:202
You might want to have it looked at before your trip. Take it from me, it really sucks to break down when you are out of town. That's personal experience talking, had 2 vehicles smoked on road trips last year. One lost a core plug(lost, not leaked), and the other had an electrical fire. First one I should have seen coming, second was right out of the blue. Felt absolutely naked, didn't have any of my usual sources or contacts to turn to. Best of luck.
Old 02-22-2010, 02:58 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
I'd take a very close inspection and skip the trip for now. At least in that vehicle. Block the rear wheels with chocks, use the E-Brake, and jack up the front. Zip off the wheels and take a look at the calipers. Disconnect them from the caliper mounting brackets and use a coat hanger to hang the calipers. Never let them hang off the brake hose. From what you describe I'm sure the pads must be toast and the rotors are warped. Take some pics and tell us what you find.
Old 02-22-2010, 07:01 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
wow thats scary once when i was driving back from getting breaks done i stepped on the petal and it when straight to the floor i had to use the ebrake sorry i cant help you though as i have limited auto knowledge.
Old 02-22-2010, 06:28 PM
Color: Garnet red
Rep:202
Incongnito is right on, those pads are baked. Good call, Incognito!
