Old 02-20-2010, 11:05 PM
jcvp jcvp is offline
Gender: Not Specified
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
jcvp is on a distinguished road
Default 94 2500 Cummins problems
So im new to this whole diesel thing... but not new to dodge... i own a 09 caliber srt4 but im having issues with the diesel...
when i turn on the ignition it has battery life and act like its going to start... but when i turn the key to start it, it looses all life and says the battery is dead.... here is what i have done to try to correct the situation so far.
new alternator, starter and 2 new batteries... both 1000 cranking amps.
snyone else got any ideas as to what i can try??
i have tried to jump it off another car but it wont take...
should i buy a charger and jump it off that?
Old 02-20-2010, 11:13 PM
Sounds like a bad connection . Once you let off the key , do the dash lights light back up ?
Old 02-20-2010, 11:30 PM
ScatPak07's Avatar
Rep:970
I'm with Tom maybe a connection somewhere. If you replaced everything associated with power then something deeper is wrong
Old 02-21-2010, 01:00 AM
Resident Technician
Rep:1909
Check your ground cables on the engine side. Make sure they're clean and tight. If you have volt meter, do a voltage drop test.
