Enabling/Disabling Personal Preferences without having an EVIC - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 02-21-2010, 02:39 AM
Magmania's Avatar
Magmania Magmania is offline
Vehicle: 2007 Ram 1500 Quad Cab (5.7L)
Trim Level: SLT Big Horn Edition
Rep:60
Magmania will become famous soon enough
Default Enabling/Disabling Personal Preferences without having an EVIC
Hello all.
I'm new to the Ram Truck but have tons of experience with my Magnum RT Wagon.
My Magnum has the EVIC option so I have never had to use the other "manual" ways of disabling features.
With a Magnum that is not equipped with an EVIC option there are ways to change some features with various different manual procedures.
As in... Auto Door Locks at 15mph, Horn Chime when locking/unlocking the door, Auto Headlight shutoff, etc, etc.
I have tried to search here for those similar procedures for the Ram Truck but all I could find in my manual and on the forum was how to disable the seatbelt chime.
Can anyone help or point me in the right direction?
Old 02-21-2010, 08:43 AM
Resident Technician
Rep:1915
What year is your truck?
Old 02-21-2010, 12:55 PM
Magmania's Avatar
Rep:60
2007 SLT Quad Cab Big Horn Edition.
Old 02-21-2010, 01:05 PM
Resident Technician
Rep:1915
You should be able to have the preferences set by the dealer via scan tool.
Old 02-21-2010, 01:27 PM
Magmania's Avatar
Rep:60
Sounds like an opportunity that they would take to make about $100 off of me for their time and labor.
Thanks for all of your input.
I do appreciate it so much!
Old 02-21-2010, 01:47 PM
Thats a feature they should put on all vehicles . I would love to see the seat heater be a function you can set . Especially when you've remote started your ride .
Old 02-21-2010, 02:03 PM
I just set all mine a few weeks ago when I got the truck. I have the same truck as you, except my cab is a bit bigger.
There is no headlight auto shutoff on my truck but I was able to set up a bunch of other stuff. Let me check my owner's manual as the setups are scattered in each section.
To unlock the doors:
Press and release the UNLOCK button on the key fob
once to unlock only the driver’s door or twice to unlock
all the doors. When the UNLOCK button is pressed, the
illuminated entry will initiate, the parking lights will
flash on twice and if installed, the cargo lamp will turn on
for 30 seconds.
The system can be programmed to unlock all the doors or
drivers door only upon the first UNLOCK button press
by using the following procedure:
1. Perform this operation while standing outside the
vehicle.
2. Press and hold the LOCK button on your key fob.
3. Continue to hold the LOCK button at least 4 seconds,
but no longer than 10 seconds, then press and hold the
UNLOCK button while still holding the LOCK button.
4. Release both buttons at the same time.
Horn Chirp
The horn chirp feature will be shipped from the assembly
plants activated. If desired this feature can be disabled by
vehicle.
2. Press and hold the LOCK button on a programmed
(i.e. functional) key fob.
3. Continue to hold the LOCK button, wait at least 4
seconds, but no longer than 10 seconds, then press and hold
the PANIC button. Release both buttons at the same time.
4. To reactivate this feature, repeat the above steps.
Vehicles will be shipped from the assembly plants with
the park lamp flash feature activated. If desired, this
feature can be disabled by using the following procedure:
vehicle.
2. Press and hold the UNLOCK button on a programmed
3. Continue to hold the UNLOCK button, wait at least 4
hold the LOCK button. Release both buttons at the same
time.
Automatic Door Lock Programming
This feature is enabled when your vehicle is shipped
from the assembly plant and can be disabled by using the
1. Enter your vehicle and close all doors.
2. Fasten your seat belt (Fastening the seat belt will
cancel any chiming that may confuse you during this
programming procedure).
3. Place the key into the ignition.
4. Within 15 seconds cycle the key from the LOCK
position to the ON/RUN position a minimum of four
times; ending in the LOCK position (do not start the
engine).
5. Within 30 seconds, press the driver’s door lock switch
in the LOCK direction.
6. Asingle chime will be heard to indicate the feature has
been disabled.
7. To reactivate this feature, repeat the above steps.
8. If a chime is not heard, program mode was canceled
before the feature could be disabled. If necessary, repeat
the above procedure.
Auto Unlock On Exit — If Equipped
This feature unlocks all of the doors of the vehicle when
any door is opened. This will occur only after the vehicle
has been shifted into the Park position after the vehicle
has been driven (shifted out of Park and all doors closed).
This feature will not operate if there is any manual
operation of the power door locks (Lock or Unlock).
Auto Unlock On Exit Programming — If Equipped
Customer Programming sequence to enable or disable
the Auto Unlock Feature:
2. Fasten your seat belt (fastening the seat belt will cancel
any chimes that may be confusing during this programming
procedure).
3. Insert the key into the ignition.
4. Within 15 seconds, cycle the key from the LOCK
times ending in the LOCK position (do not start the
engine).
in the UNLOCK direction.
6. A single chime will sound to indicate the feature has
been changed.
7. Repeat the above steps to alternate the availability of
this feature.
before the feature could be changed. If necessary repeat
Enhanced Seat Belt Reminder System (BeltAlert)
If the driver’s seat belt has not been buckled within 60
seconds of starting the vehicle and if the vehicle speed is
greater than 5 mph (8 km/h), the Enhanced Warning
System (BeltAlert) will alert the driver to buckle their seat
belt. The driver should also instruct all other occupants to
buckle their seat belts. Once the warning is triggered, the
Enhanced Warning System (BeltAlert) will continue to
chime and flash the Seat Belt Warning Light for 96
seconds or until the driver’s seat belt is buckled. The
Enhanced Warning System (BeltAlert) will be reactivated
if the ignition is cycled, driver’s seat belt is unbuckled for
more than 10 seconds and the vehicle speed is greater
than 5 mph (8 km/h).
The Enhanced Warning System (BeltAlert) can be enabled
or disabled by your authorized dealer or by
following these steps:
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. DaimlerChrysler does not recommend
deactivating the Enhanced Warning System
(BeltAlert).
1. With all doors closed and the ignition switch in any
position except On or Start, buckle the driver’s seat belt.
2. Turn the ignition switch to the ON position and wait
for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of turning the ignition switch to the
ON position, unbuckle and then re-buckle the driver’s
seat belt at least three times within 10 seconds, ending
with the seat belt buckled.
NOTE: Watch for the Seat Belt Warning Light to turn on
while unbuckling and off while re-buckling the seat belt.
It may be necessary to retract the seat belt.
4. Turn the ignition switch to the LOCK position. A
single chime will sound to signify that you have successfully
completed the programming.
The Enhanced Warning System (BeltAlert) can be reactivated
by repeating this procedure.
NOTE: Although the Enhanced Warning System
(BeltAlert) has been deactivated, the Seat Belt Warning
Light will continue to illuminate while the driver’s seat
belt remains unbuckled.
Old 02-21-2010, 03:54 PM
SilverMaggie's Avatar
SilverMaggie SilverMaggie is offline
Vehicle: 2007 Dodge Ram 1500
Rep:81
SilverMaggie will become famous soon enough
Very helpful information, Thanks MADDOG!
[CENTER][SIGPIC][/SIGPIC][/CENTER]
Old 02-21-2010, 10:19 PM
Magmania's Avatar
Rep:60
MADDOG you are the man!
This is exactly what I was referring to but I was unable to find them in the manual.
I already did the "All doors Unlock" one.
Thanks again!
Old 02-21-2010, 10:35 PM
Resident Technician
Rep:1915
I'd say you need to find a new dealer.
