4 wheel drive problem, frustrated - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-22-2010, 01:58 PM
bigdon bigdon is offline
bigdon is on a distinguished road
Default 4 wheel drive problem, frustrated
I have a 99 RAM extended, 4 wheel drive (obviously). Problem is it keeps clunking in low and high, while engaged. It's obviously dropping out of 4 wheel. Tried changing vacuum shift motor to no avail, checked vacuum lines, they are ok. Already checked shift fork for breakage or cracks. I don't know what else to check, It's no fun living in Chicago and not being able to use your 4 wheel drive that I've become accustomed to. Can anyone help me? I was hoping maybe some one else might have had this problem in the past. Please, please help!
Old 02-22-2010, 02:00 PM
iRESQu iRESQu is offline
Rep:2217
Welcome to the Forumz. While others are sure to chime in to help, it helps us if you would please fill out your User CP with all the details of your truck. Sorry I couldn't offer immediate help. Stick around, I promise others will write.
Old 02-22-2010, 02:20 PM
Resident Technician
Rep:1915
Have you checked the vacuum switch on the transfer case? It's a pretty common failure.
Old 02-22-2010, 02:47 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
hello and welcome, sorry i can help i tend to make problems worse
Old 02-25-2010, 05:06 PM
Remerson 228< thanks for chiming in, unfortunately I already replaced the switch. I hope I can get some more people with some help I know I cant be the only one whose had this problem. I look forward to more help like you.
Old 02-25-2010, 05:20 PM
Resident Technician
Rep:1915
Perhaps these will help then!
Old 03-03-2010, 05:33 PM
pantera101188666 pantera101188666 is offline
pantera101188666 is on a distinguished road
is the transfer case itself going from for hi to for lo vice versa? becuse i had a simalar problem with my truck and the transfercase linkage needed to be adjusted.
