Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 02-22-2010, 01:30 PM
Rider12 Rider12 is offline
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rider12 is on a distinguished road
Default Erratic shifting
My 5.9 cummins 24 valve has been acting strangely during highway driving, it will randomly unlock the tourque converter re-lock numerous times for no apparent reason, it will sometimes shift out of overdrive into drive for no apparent reason, it will also sometimes randomly shut off the cruise control itself, and every once in a while the rpm guage will go nuts jumping all over the place before returning to normal. I already know that my tranny is working properly I was thinking maybe an engine speed sensor or something like that anybody ever run across something like this?
Old 02-22-2010, 01:56 PM
Rep:1890
Check the ECM and TCM for codes? What year is the truck?
Old 02-22-2010, 02:18 PM
iRESQu iRESQu is offline
Rep:2217
Hello and welcome to the Forumz.
Old 02-22-2010, 03:44 PM
sorry its a 99 and it is also chipped could that have anything to do with it?
Old 02-23-2010, 12:44 AM
2000 Ram 2500 2000 Ram 2500 is offline
Rep:13
2000 Ram 2500 is on a distinguished road
Output shaft speed sensor/Vehicle speed sensor can cause everything you are describing. Whether it is located on the tranny or the rear axle on your application though...I cannot answer.
Old 02-26-2010, 03:57 PM
Could a transmission temperature sensor gone bad cause what I am describing also, I just thought that a bad output speed sensor would keep the tansmission from shifting out of first, not sure though
Old 02-28-2010, 01:39 AM
Skipp Skipp is offline
Vehicle: 2001 2500 Ram
Skipp is on a distinguished road
Had the same problem with my 2001 diesel.
It would shift in and out of gears and sometimes wouldn't shift up.
Took it to Dodge and turns out it was a sensor in the transmission
$600 later it was fixed.
Old 02-28-2010, 08:33 AM
Rep:1890
I can't imagine the speed sensor causing the tach to go haywire.
Old 05-01-2011, 06:59 PM
grglry grglry is offline
Vehicle: 1999 dodge ram 3500
grglry is on a distinguished road
My 1999 3500 seems to shift in and out of overdrive by itself and doesn't seem to know which gear it wants to stay in. I was told it may be a grownding problem from any cable that go to the main computer .
Old 05-22-2011, 03:51 PM
DODGECUMMINSWOODY DODGECUMMINSWOODY is offline
Vehicle: 2001 2500 4x4
DODGECUMMINSWOODY is on a distinguished road
I was just woundering if you got the issue fixed because I'm having the same issue except below 50 mph
