Old 03-23-2011, 11:46 AM
caduceus caduceus is offline
Vehicle: 1999
Trim Level: basic
caduceus is on a distinguished road
Default 1999 ram diesel speeds up very slowly at times...
Hi, im new around here simply because this would be my first ram truck (which I loved for the 1st week) I got this truck about 1 month ago. Things last owner told me "Injector pump was replaced, and transmission was rebuilt"
Now here is the problem, I can step on gas all I want, but the truck will take its time speeding up (really slow), its so bad that i fear getting on the highway. It seems that if i let go of the gas and step on it again it speeds up the way it should. Another problem is morning starts. It takes a few cracks to start up. I dont know if these two symptoms relate.
I took it in the shop, and the guys told me that it could be the injector pump was not align correctly inside the timing cover. Ive done some reading and ive seen some "it could be..." with similar problems. I offer thanks in advance.
1999 ram 2500 6 cyl. diesel
Old 03-25-2011, 02:42 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Are you cycling the grid heaters before starting it?
Old 03-25-2011, 03:18 AM
RamTrucker RamTrucker is offline
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
RamTrucker is on a distinguished road
check the fuel pressure...check the transmission for trouble codes...
Old 03-25-2011, 01:40 PM
Vehicle: 1999
Trim Level: basic
Thanks for your respose, Im not sure how to do this, if you mean warming the truck up... then yes, I leave it running before I take off. If there is something im missing please let me know.
Thanks for your response too, I have not checked it, but ive been reading about "Lift pumps" and some of these symptoms are similar to mine, The only problem is that... People suggest to replace the lift pump, and the guy with the problem just dont post an answer. I forgot to mention that when i took it in the shop i was charged $200 and got a "it could be that the injector pump was not aligned correctly" answer. So before I go and blow $500 on a lift pump, can someone verify if these is a possible solution? im gonna google on how to check fuel pressure. Thanks again guys, hope I get this fixed soon.
ps. It will take me a while to respond because im out my house every day almost all day.
Old 03-25-2011, 05:45 PM
Color: Mineral Gray
Rep:177
[QUOTE=caduceus;482402]Thanks for your respose, Im not sure how to do this, if you mean warming the truck up... then yes, I leave it running before I take off. If there is something im missing please let me know.
QUOTE]
Before you even try turning the motor over you need to turn the key to the on position and you should seed either an orange light that looks like a coil or it may say "wait to start" some where on your gauges. You have to leave the key in the on position till that light shuts off. If its below ten degrees out its a good idea to put the key back into the off position,wait a few seconds and back to the on position to let the grid heaters cycle again like you just did, once the light goes out your truck should start easier.
I have no idea about automatics in this trucks so I cant really help you much there.
Old 03-25-2011, 08:02 PM
Vehicle: 1999
Trim Level: basic
[QUOTE=Stangshcky12;482608]
QUOTE]
Ok i understand the term now, yes I let the truck on for a few seconds before I crank it. Its been around 10-20 the past few mornings, so I let it sit in that position for a few seconds. Ok, Im gonna try my luck with the lift pump, this weekend or next, I found a used one "airdog" for $100 here in Denver, so ill keep you guys posted if this was the issue or not. Thanks for the advice.
Old 11-03-2011, 08:54 PM
ewo ewo is offline
Vehicle: 2002 Dodge Ram 2500 Cummins
Color: blue
ewo is on a distinguished road
did replacing the lift pump fix the problem? I am having similiar issues with my 02 cummins.
Old 11-27-2011, 03:52 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
I know im late to the party so if this ever gets looked at this another spot to look on the newer eng is the drive by wire, pedle regulator and tps
Old 02-03-2012, 11:42 AM
gfmccutc77 gfmccutc77 is offline
Vehicle: 2001 Dodge Ram 2500
gfmccutc77 is on a distinguished road
I'm late to the party too, I had this problem on my 01. The Camshaft positioning sensor went out on my truck. Killed the turbo and wouldn't speed up for anything.
Old 05-27-2012, 05:37 PM
cape99ram's Avatar
cape99ram cape99ram is offline
Vehicle: 1999 dodge ram 1500 4x4
Trim Level: slt laramie
Color: silver
cape99ram is on a distinguished road
is it smoking black a all? or feel like its bogging? could be a bad turbo
Coolant loss in 1999 Dodge Diesel 3500 dually kebro004 Cummins Diesel Specific Topics 3 07-14-2010 12:19 AM
Oil filters by Brand & Manufacturer GTyankee Oil Change 10 04-08-2010 12:34 AM
1992 Dodge Ram w/ Cummins diesel Tranny options? Russ Bellinis Cummins Diesel Specific Topics 2 06-11-2009 03:55 PM
