Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 02-22-2010, 04:00 PM
Falconcon Falconcon is offline
Vehicle: 2005 Dodge Ram 2500
Trim Level: Slt big horn
Color: gray
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Falconcon is on a distinguished road
Default '05 ram 2500 vibration
I'm wondering if anyone knows what might be the cause of a vibration I get when accelerating from a stop up to about 25 mph. 145k on the truck w/AT.
Could it be a u-joint + if so how do I tell which one?
Thanks
Old 02-22-2010, 04:03 PM
Rep:1845
The best way to check the u-joints is to index mark and remove the shaft to check for looseness or binding. Check your engine and trans mounts as well.
Old 02-22-2010, 11:03 PM
Color: gray
I'll give that a shot. Thanks for the advice!
Old 02-22-2010, 11:20 PM
Wasn't there a TSB on this ?
Old 02-23-2010, 01:36 AM
2000 Ram 2500 2000 Ram 2500 is offline
Rep:13
2000 Ram 2500 is on a distinguished road
Sounds like a driveshaft center bearing issue to me. Especially if it is extended cab or 4-door and has a 2 piece shaft? I say that due to a u-joint issue gets worse with speed. Its not going to only do it till 25mph. The issue you are describing is usually caused from center bearing/isolator failure. Or improper driveshaft angle due to a suspension lift. If the latter is the case, the lift companies actually make brackets that mount between the frame and the driveshaft center coupling to bring the angle closer to its stock location....If is not lifted you may just have a worn out center assembly...
Old 03-17-2010, 01:51 AM
StrikerRam StrikerRam is offline
StrikerRam is on a distinguished road
Hey Guys...i got the same problem with my '06 Ram Laramie QC with just 57clicks now...i just had my tire rotated and...vibrations still there...im scared im going to spend an amount for it...thanks 2000Ram2500 !!!
