Old 02-22-2010, 05:55 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Default Clicking Noise Grrrrrrrrrrr
So today noticed a clicking noise from the front end . It only does it in 2wd and goes with the speed of the vehicle. I cannot hear it when its in reverse either, but it may still be there. I did a search and seen that it could be u-joints, bearings, and seals going out. Every once in awhile it vibrates the front end at highway speeds, but I left off, and it goes away. I need ball joints on the driver side, and my steering stabilizer is leaking (or so Car-X said), could be those seals.
I am going to take it to someone with a lift and can get underneath my truck, but wanted to get some ideas before I went.
Old 02-22-2010, 06:12 PM
Rep:1885
A leaking stabilizer requires replacement. Check you'r rear driveline carefully.
Old 02-22-2010, 06:20 PM
Rep:1930
yeah I was planning on replacing the driver side ball joints, and the steering stabilizer, but now I need to plan to add other things I think. Luckily I am not going to be able to drive for another week or so, till my cast gets removed,so hopefully get it looked at/fixed this weekend.
Old 02-22-2010, 08:34 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
thats weird that it just does it in 2wd!!!!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
