Old 02-22-2010, 06:05 PM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
Default Check Engine Code P0157
As i posted last week my check engine light came on then turned off and hasnt come on since. I checked the code today and it was P0157 just wondering if anyone knows what that is.
Old 02-22-2010, 06:16 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
P0157 Oxygen Sensor Circuit Low Voltage (Bank 2 Sensor 2). Could just be a one time thing. I would wait to see if it comes on again, unless you are having any other problems(fuel economy, running rough, etc). If the code went out, the condition that set it is resolved and the code is stored for later diagnostics. I would not reset the computer, just leave the code stored.
Old 02-23-2010, 07:48 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
if it's sensor 2, bank 2.. that is the O2 sensor after the cat on passenger side...this sensor only monitors the cats so I wouldn't be too worried about it...did you change your exhaust at all?
Old 06-10-2012, 08:30 PM
kombucha20's Avatar
kombucha20 kombucha20 is offline
Vehicle: 2005 Dodge Ram 1500 Hemi 5.7
Color: grey
kombucha20 is on a distinguished road
I'm getting the same error code, I just installed headers, I removed the cats, the error code just popped up today but Iv been running the truck for about a week without any codes, I tried clearing it with my programmer but it keeps comming back, and it seems to burning a little more fuel then normal
05Ram Hemi 4x4,K&N CAI,Magnaflow duel exhaust,SC Programer, srt10 hood
Old 06-10-2012, 08:58 PM
Rep:2657
P0157-O2 SENSOR 2/2 CIRCUIT LOW VOLTAGE
When Monitored: Engine running for less than 30 seconds and the O2 Sensor Heater Temperature is less than 251C (484F) with battery voltage greater 10.4 volts.
Set Condition:
The oxygen sensor signal voltage is below 2.411 volts for 10.24 seconds after starting engine. One Trip Fault.
POSSIBLE CAUSES
O2 SENSOR BELOW 2.52 VOLTS
O2 SENSOR O2 RETURN CIRCUIT SHORTED TO GROUND PCM
Old 06-11-2012, 10:36 AM
chefred112's Avatar
Rep:656
in your case you need to do something to the sensors since you've gone catless.. you can try using spark plug foulers which moves the sensor out of the direct exhaust path..
Old 06-14-2012, 06:00 PM
kombucha20's Avatar
Color: grey
right on thanks, i;ll give those a try
