EVAP leak - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 02-22-2010, 09:12 PM
floquito007 floquito007 is offline
floquito007 is on a distinguished road
Default EVAP leak
hello,
sorry dont even know if i spellt it right.
my check engine light is on and the code says evap leak. what is that?
Old 02-22-2010, 09:15 PM
Resident Technician
Rep:1915
I'm means you have a leak in the evaporative emissions system. Most likely you have a loose/defective fuel cap or a bad hose.
Old 02-22-2010, 09:57 PM
2000 Ram 2500 2000 Ram 2500 is offline
Rep:13
2000 Ram 2500 is on a distinguished road
Originally Posted by floquito007 View Post
hello,
The Evaporative emmisions system is designed to burn the fuel vapors from the fuel tank instead of releasing them into the atmosphere. The system consists of a Vapor management valve, Fuel tank pressure transducer, vapor management canister, and canister purge solenoid. The PCM monitors system pressure throughout drive cycles. If the system indicates low pressure from the FTP for three consecutive cycles, the check engine light is illuminated. Usually a code P0443/0444/0445. Depending on the size of the leak. Most likely causes are a loose gas cap(Or defective seal), defective purge solenoid(CPS), Faulty Fuel Tank Pressure Transducer(FTP),or sticking Vapor Management Valve(VMV)(The valve that releases vapors to the intake maifold for combustion). Check your gas cap fitment and roadtest the vehicle at a steady 45mph for atleast 15 minutes. If the light goes back off you know that was it. If not, you will have to take it to the dealer so they can perform a proper EVAP system diagnosis....
Old 02-23-2010, 12:00 AM
Nice explanation there .
Old 02-23-2010, 01:28 AM
Rep:13
Hey thanks! Dont let my newb status fool you. I have been around a vehicle or two....
