Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2010 Dodge Ram Forum
Old 02-23-2010, 01:07 AM
JaredConspiracy's Avatar
JaredConspiracy JaredConspiracy is offline
Rep:243
JaredConspiracy has a spectacular aura aboutJaredConspiracy has a spectacular aura aboutJaredConspiracy has a spectacular aura about
Default Need some assistance.
can someone give me a detailed "how to" as to how to take off the grill completely, the top bumper piece that outlines the bottom of the headlight, and the rear ram head badge?
Old 02-23-2010, 03:12 PM
Rep:2766
i think this may help you, its from a company that sells grills
http://74.125.155.132/search?q=cache...&ct=clnk&gl=us
Old 02-23-2010, 03:22 PM
Resident Technician
Rep:1915
REMOVAL
<A xmlns="http://www.w3.org/1999/xhtml"> 1.Remove the four push pins (1).2.Remove the two plastic rivets (2) and remove the upper radiator seal.
<A xmlns="http://www.w3.org/1999/xhtml"> 3.Remove the four upper grille support bolts (1).
4.Using trim stick C-4755 or equivalent, separate the two lower spring clips (2).5.Release the two lower hooks (1) and remove the grille.
Old 02-24-2010, 01:17 AM
Rep:243
good info! but what the heck is "Using trim stick C-4755 or equivalent"?
Old 02-24-2010, 01:26 AM
Rep:2766
http://www.millerspecialtools.spx.co...l.aspx?id=1159
C-4755 is a trim stick to pull up bezels, trim panels and other things without destroying or marking them. You can buy them at most auto stores. They make nice ones that are thin and flat and blunt so they won't mark anything. There are plenty to choose from.
Old 02-24-2010, 11:03 AM
Rep:243
k sweet i guess ima hafta pick one of those up.
