Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 02-24-2010, 12:43 AM
2002Sport 2002Sport is offline
Vehicle: 2002 Dodge Ram 1500 Sport
2002Sport is on a distinguished road
Default Rough Idle when first started
I have a 2002 Ram 1500 with a 5.9L 360. When I first start the truck after sitting, say overnight, it starts fine, but after a few minutes it begins to idle rough and sounds like its almost going to stall. After a minute or two of this, it begins idling fine and runs fine. This happens every time the truck has been sitting for more than a couple hours. If I attempt to drive during this "bad idle" phase, it sputters, has loss of power, and sounds like its backfiring. I never have any problems while driving the truck, only during this cold startup.
The only why I can avoid this situation is if i start the truck, let it run for a minute, turn it off and start it up again. Then, the problem goes away. Any thoughts?
Old 02-24-2010, 12:49 AM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
I have the same thing, and so do others. It's like its transitioning from the high idle when its cold down to the regular idle. Dunno why, sounds like it has a really lopey cam. I wouldn't worry too much about it.
Old 07-12-2010, 03:32 PM
Mac's Avatar
Mac Mac is offline
Vehicle: '99 Dodge Ram 1500 4x4
Color: solar yellow
Rep:83
Mac will become famous soon enough
2002Sport, did you ever get this figured out? My '99 sport is doing the exact same thing. Starts fine, idles fine for about 60 seconds, then starts chugging. Although, I'm able to drive mine just fine, only the idle and only when cold.
I JUST had my plenum gasket replaced so it must be something to do with the TB or the idle air sensor thingy. I asked the guy to clean the TB while it was off, maybe he forgot.
Old 07-18-2010, 01:01 AM
Mac's Avatar
Mac Mac is offline
Color: solar yellow
Rep:83
Hmm, mine seemed to work itself out. Idling fine now. Might have been the Shell fuel.
Old 07-18-2010, 02:20 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
Mine does something similar to this, but, it didn't matter what temp or anything. Just anytime the truck was at idle, it would start chugging, sounding like a lopey cam, and if I let it go long enough, it would stall out, unless I revved it up or something.
So, I got underneath the truck and unplugged the o2 sensor, and my truck runs great now...no problems since. So, I'm getting a new o2 sensor. I asked the dodge dealer and they told me that "if unplugging it fixes the problem, its your problem."
Once I get a new o2, I'll let you guys know whether it fixed it or not.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 07-18-2010, 01:36 PM
Mac's Avatar
Mac Mac is offline
Color: solar yellow
Rep:83
They actually said that?! Yeah man, let us know what the new O2 sensor does.
Old 07-18-2010, 02:04 PM
That's interesting and good info on the O2 sensor. But you weren't getting a code on the sensor???
Old 07-18-2010, 02:08 PM
Rep:1885
Older OBDII systems won't pick up faults like the newer stuff will.
Old 07-18-2010, 02:44 PM
mattg1500's Avatar
mattg1500 mattg1500 is offline
Vehicle: 2005 Dodge Ram QC
Rep:22
mattg1500 is on a distinguished road
I had a bad EGR that did that on my old dodge and 1 other time it was the cap and rotor. On my HEMI it needed to be re flashed and that fixed it, not sure if this helps you
Old 07-18-2010, 02:46 PM
I remember some of that. My '95 ImpalaSS didn't flash too many codes but it seemed I was always fixing something on that car.
