Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 02-24-2010, 11:01 AM
Dieselkiss's Avatar
Dieselkiss Dieselkiss is offline
Vehicle: 99 Ram 1500
Trim Level: ST - Very Base Model
Color: Red with grey
Rep:48
Dieselkiss is on a distinguished road
Default 1500, 2500, 3500 differences.
I was looking at a 2500 the other day and trying to see the differences.
Is it just mechanical (suspension, steering, engine etc)?
or do the bigger load truck have different body and chassis?
Old 02-24-2010, 11:30 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
1/2 ton frame, 3/4 ton frame, and 1 ton frame. i think in the 2nd gen the bodys were the same,except the 1 tons only came dually??? Wheels are different too, 5 bolt to 8 bolt.
Old 02-24-2010, 01:01 PM
Dieselkiss's Avatar
Rep:48
Thanks werm.
Old 02-24-2010, 01:36 PM
ltdan ltdan is offline
Vehicle: 2016 Ram 1500
Trim Level: Lone Star
Rep:36
ltdan is on a distinguished road
There's a crapload of differences.
The 2500 and 3500 have a different frame and suspension to handle more weight, heavier duty axles, wheel bearings, springs, steering, etc. the '09 HD trucks have the same body as the '02-'08 1500s, and the 2010 Chassis Cabs do to. The 2010 HDs have a new body based on the '09 1500, as will the 2011 CC. The interior of the 2010 HDs is the same as the '09 1500. 2500s come with either a Hemi or Cummins Diesel, and the 3500s come with the Cummins only. The 3500 is available with single or dual rear wheels.
Old 02-24-2010, 01:37 PM
Dieselkiss's Avatar
Rep:48
Thanks for the info, dan.
Old 02-24-2010, 05:17 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
also a big money difference!!!!! lol.
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 02-24-2010, 09:08 PM
ScatPak07's Avatar
Rep:970
The higher the number the more weight capacity it can take. You will have a beefier suspension going from 1500-2500. Basically everything that itdan has said above. He coverd the majority of it
Old 02-24-2010, 09:27 PM
Rep:3337
The 1500s are also only availiable with a gas engine, the 2500 and 3500s can get the 5.7L cummins. The suspensions are beefier, my dad had to put almost 1000lbs in the back to keep traction of his 3500 as opposed to the 300lbs it took in my 1500.
Old 02-24-2010, 09:31 PM
thereverendbill thereverendbill is offline
Vehicle: 1995 Dodge Ram 2500 8800 GWV
Trim Level: bare bones
Color: marron soon to be black
Rep:21
thereverendbill is on a distinguished road
maybe if your looking at a new truck ...... I picked my 2500 up for a measly 600 bucks, when buying used Ben Franklin is the ultimate negociator :P
Old 02-24-2010, 10:09 PM
Florida Roadie's Avatar
Florida Roadie Florida Roadie is offline
Vehicle: 2003 Ram 2500 Diesel
Florida Roadie is on a distinguished road
Actually Scat I believe in years 03 thru 05 the 2500 series has a pay load and tow limits greater than the 3500 dual wheel. The 2500 has a gvw 1000 lbs higher than the 3500... the tow weight is also 20,000 lbs. for the diesel HD 2500 03 thru 05 with the 4.10 rear and only 19,000 for the same equip. 3500 ..Both with cummins .Check it out @ Gino's garage where the charts are easy to follow .
Florida Roadie
