Old 02-24-2010, 10:45 PM
dodgeramdriver's Avatar
dodgeramdriver dodgeramdriver is offline
Vehicle: 2005 Dodge Ram 1500 Quad Cab
Trim Level: SLT 4X2
Color: Dark Blue
Rep:13
dodgeramdriver is on a distinguished road
Default Tire Cupping with slight pull to right
Has anyone else had a tire cupping problem with their truck? My tire has a even cupping throughout the tire on the front passenger side tire.
I took it in to get an alignment because the tire was cupping and because I had just bought the truck. The alignment place told me that the alignment on it was damn near perfect and that there was nothing wrong with the trucks suspension components. They said the cupping comes from the tires that the dealer put on the truck were used. I think they are wrong. I'm thinking it might be a worn upper ball joing or tie rod end on it. Will a used tire continue to cup deeper once it has started?
Old 02-24-2010, 11:45 PM
streetbob streetbob is offline
Vehicle: 2002 Ram 1500
Rep:28
streetbob is on a distinguished road
most likely a week shock, rotate the tires and listen to the noise behind you for a while. But cupping is almost always shocks, if not worn, not stiff enough.
Old 02-25-2010, 06:24 AM
Trim Level: SLT 4X2
Color: Dark Blue
Rep:13
Thanks. I will change the shocks out this weekend and rotate the tires. Any recommended brand shocks for the truck. Or is it on to just use the regular shock from autozone?
Old 02-25-2010, 01:06 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
I liked the Monroe Reflexes on my Exploder, haven't had to do shocks on the Ram yet. Probably dependent on how you drive and whether or not you tow.
Old 02-25-2010, 04:34 PM
Rep:1909
Cupping on one tire is uncommon. Feathering however, is not. Got a pic of the tire in question? Check to see if there is any sign of leakage from the shocks and if they're dry, pull them loose and see if they are indeed bad before replacing them. Also, do you have a copy of the alignment spec sheet?
Old 02-25-2010, 08:47 PM
Trim Level: SLT 4X2
Color: Dark Blue
Rep:13
What is the difference between cupping and feathering? I will have a pic up in a second. And I didn't get the spec sheet from the alignment place. I just took their word for it that it was ok. I figured that they had the opportunity to charge me for an alignment and didn't so they were telling me the truth.
Rep:28
I replaced my shocks about 6 months ago with Pro comps and I hate them, you would think i replaced them with sticks! I have a 125000 on my truck, long wheel base and I am going back to the dealer and buy the oem shocks. I was always kinda proud that my truck didn't bounce your molars out on the freeway and after changing them all I can say is Holy cr**! Remerson is right though, after posting I started thinking about the pulling to one side. What factory specs and truly aligned can be two different things. Factory specs allow alot tolerance but a good front end man can pull it in where it truly belongs, tighter than factory tolerance. It may just need to be tweeked a little. Good luck, my friend.
Old 02-25-2010, 08:57 PM
Trim Level: SLT 4X2
Color: Dark Blue
Rep:13
All 3 of these pics are of the front passenger tire. I will take the shock off and check it first thing tomorrow morning.
Old 02-25-2010, 08:59 PM
What kind of tires are they ? I had problems with my Goodyears cupping and once i put BFG's on it the problem has never happened again .
Old 02-25-2010, 09:16 PM
Trim Level: SLT 4X2
Color: Dark Blue
Rep:13
They are some Goodyear Tracker 265/70/17. I plan on buying new set of tires in a month or so. I wanted to make sure that I don't mess the new tires up on the truck once I get them on there.
alignment, cupping, tire
