Old 02-25-2010, 09:36 AM
Dieselkiss's Avatar
Dieselkiss Dieselkiss is offline
Vehicle: 99 Ram 1500
Trim Level: ST - Very Base Model
Color: Red with grey
Rep:48
Dieselkiss is on a distinguished road
Default Bizzare Low fuel gearbox issue!!
My brother in law doesn't have access to the net so I said I'd ask this for him.
He has a 2000 Ram 5.9 Magnum, 2wd, Auto box. When it is on E on the fuel tank it won't change out of first gear. Occasionally he can abuse the kick down and it will change but as soon as he stops and starts it again it stay in first again.
Soon as he drops some fuel in (even just $10) the gear change works just fine.
This is a little odd. We did think it might be a sensor, but it doesn't make sense that it would hold it in a lower gear with higher revs when you're low on fuel, unless it's intended to make you drive slow.
Anyways, anyone ever had this issue or know what may be causing it?
Old 02-25-2010, 06:44 PM
ScatPak07's Avatar
Rep:970
That is a weird situation. Your right you would want it to be in a higher gear at lower RPMs to save the fuel, not ripping it in the higher revs haha.
Thats gotta be some sort of electricl problem causing the empty signal to screw with the auto trany
Old 02-25-2010, 07:14 PM
Its not engineered that way . Never heard of a problem like that . Strange .
Old 02-26-2010, 05:49 PM
Dieselkiss's Avatar
Rep:48
Ok, was definitely an issue because just last night his gearbox died completely!!
Hopefully the new gearbox he's putting in will cure the issue.
Old 02-26-2010, 05:55 PM
jasonl844's Avatar
jasonl844 jasonl844 is offline
Vehicle: 07 dodge ram
Color: red
Rep:26
jasonl844 is on a distinguished road
keep us posted on how things turn out!
Old 02-27-2010, 11:02 AM
Zekery360 Zekery360 is offline
Vehicle: 2002 Dodge Ram
Color: Bright Red
Zekery360 is on a distinguished road
Let us know for sure what that is... So weird...
