Old 02-26-2010, 12:22 PM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
Default Trasmission Help!!!
I didnt see a transmission section and my ram is a 5.9 so i figured it would be best here.
OK so my auto transmission wont shift out of 1st gear till around 3500 rpm. The other gears shift perfectly and this just happened yesterday. I noticed last week When I put it in drive it was sluggish in 1st but it shifted like normal and at the correct rpm. I checked the fluid and its where it should be. Could it be my torque converter? or am I up the creek without my paddle!!!!
Any help here would be great cuz when it comes to transmissions it all french to me.
Old 02-27-2010, 03:37 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
im just moving the thread up
Old 02-27-2010, 04:14 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
It's a Hail Mary, but mine had problems in lower gears when I got it. Turned out the throttle pressure cable had come loose from the tranny. It had been rebuilt before it ended up on the lot, and looks like it was missed. Hope it's something that simple.
Old 02-27-2010, 03:47 PM
bigjeff64's Avatar
Rep:20
I am thinkin of changin the TPS and the auto parts store told me to check the cable so hopefully ill get somethin out of this
Old 02-28-2010, 01:40 AM
bigjeff64's Avatar
Rep:20
well i changed the Throttle Position Sensor and and the guy at the store told me that the computer needs to learn the new part. I checked the Linkage cable and that was snug but they told me that it could be the vacuum line to the transand there is also a check valve in the line that could be open as well. Can anyone clarify any of this? I have the 46RE tranny so any and all help will be much appreciated.
Old 02-28-2010, 08:57 AM
Need to scan it and see if you have any codes . Could be something as simple as a input or output speed sensor .
Old 02-28-2010, 09:13 AM
Rep:1877
The parts store guy is talking out of his ass. Throttle position isnt a learned input. Have you tried adjusting the cable?
Old 02-28-2010, 10:49 AM
bigjeff64's Avatar
Rep:20
No i havent adjusted the cable yet!!! I havent had much experience with trans so is that hard to adjust? what do i have to do?
Old 02-28-2010, 10:51 AM
bigjeff64's Avatar
Rep:20
I scanned the truck when I bought it and there were three codes. 1 was about the gas tank and the other 2 had somethin to do with pressure and voltage with the govenor but these codes have been on there for months and there never was a problem until now.
Old 02-28-2010, 10:52 AM
Rep:1877
I'm a bit confused. Your profile says your Ram is a 2004 but you say it has a 5.9 (presumably gas) and your pic is the BE body. I can get you the adjustment procedure if you give me the specifics.
