How do I remove the wiper arms? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 02-26-2010, 04:20 PM
RDabate RDabate is offline
RDabate is on a distinguished road
Default How do I remove the wiper arms?
Hi guys,
I need to replace my wiper motor, so I'm pretty sure I need to take these arms off so I can take the molding off so I can access the motor.
How ever, I don't see an easy way to get the Wiper arms off.
Any suggestions?
1999 Dodge Ram 1500 Sport, 5.2
Old 03-10-2010, 02:35 AM
marlin336 marlin336 is offline
Vehicle: 2000 Dodge Ram
marlin336 is on a distinguished road
Don't remember for sure, but I think they have a little retaining clip you pull out. Just pull up on the wiper and let it bend at the joint. Once bent up, you can take a small screwdriver (sometimes your finger) and slide out the small retainer as far as it will go. The wiper should pop right off. If not, just try to rock back and forth until she comes loose. I don't think the clip will slide out without bending up the wiper arm at the hinge. Hope this helps.
Old 03-10-2010, 03:04 PM
Ramrob Ramrob is offline
Vehicle: 1999 Dodge Ram 1500 5.9L
Rep:75
Ramrob will become famous soon enough
Yes there should be a little tab were it's splined. You pull the tab out and lift up. I had stripped 2 wiper arms already.
Old 03-10-2010, 03:13 PM
Resident Technician
Rep:1915
WIPER ARM
CAUTION: The use of a screwdriver or other prying tool to remove a wiper arm may distort it. This distortion could allow the arm to come off of the pivot shaft, regardless of how carefully it is installed.
  1. Open the hood of the vehicle.
  2. Lift the wiper arm to permit the latch to be pulled out to its holding position, then release the arm. The arm will remain off the windshield with the latch in this position
  3. Remove the wiper arm from the pivot using a rocking motion.
  4. Install the wiper arm and blade with the wiper motor in the Park position.
  5. Mount the arms on the pivot shafts so that the tip of the wiper blade is on the upper edge of the lower windshield blackout area 22 mm ( 0.86 in.)
  6. Lift the wiper arm away from the windshield slightly to relieve the spring tension on the latch. Push the latch into the locked position and slowly release the arm until the wiper blade rests on the windshield.
  7. Operate the wipers with the windshield glass wet, then turn the wiper switch to the Off position. Check for the correct wiper arm positioning and readjust if required.
Old 01-02-2011, 09:15 PM
Aryana Aryana is offline
Vehicle: 1986 Dodge Ram
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
Aryana is on a distinguished road
Would this also work on a 1986 Dodge 3500? I need to get into the wiper motor to re attach the arm.
Old 11-10-2014, 10:42 AM
Jon89 Jon89 is offline
Vehicle: 1999 Ram 5.9 V8 1500 Series
Trim Level: Laramie SLT
Jon89 is on a distinguished road
My 1999 Ram wiper arms have never been off the truck. I'm having my cracked windshield replaced tomorrow morning and both wiper arms must come off first. The nut that holds the wiper arm on its pivot shaft is covered by a small metal cap that appears to be hinged to the wiper arm. I've tugged on the cap with pliers and a screwdriver but it does not budge. Is it rusted in place, or am I not following the proper procedure to lift this hinged cap up so I can remove the nut and then the arm?
Any help would be greatly appreciated....
Old 11-11-2014, 07:19 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Default 2nd Gen wiper arms
I'm thinkin' I got here too late.
But you are mostly correct. Sometimes they can be stubborn.
