Old 02-27-2010, 06:25 PM
Travis Travis is offline
Vehicle: 2014 Ram 2500
Trim Level: Outdoorsman
Travis is on a distinguished road
Default How bad are the auto's in a 2nd gen ram?
I have a 99 ram 1500 sport, auto, 3 inch suspension lift, going to do the 360 engine swap, when we don't have a ton of snow here in west virginia. The truck had the auto trans rebuilt about 800 miles before I got it. New lines were run to avoid the check valve, as well as an after market trans cooler. I have always had a manual trans in all my vehilcles, and I am quite hesitant to put a lot of money in this truck as it is an auto, and everything I have read doesn't seem to favorable for them.
How reliable are these trans? I know it depends on type of driving, but the truck will get the occational offroad trip, towing a car trailer with a car, and probably hauling a 4 wheeler around as well. Will the trans hold up to this kind of abuse, or should I get a truck with a 5 speed? Also, if I do keep it, is an advance auto torque converter ok, or would there be a better place to get one that isn't 4 or 5 hundred dollars? Sorry about the long post, just wanting some more info about the reliablily with these transmissions. I am also planning to run 33x12.50 tires.
Thanks.
Old 02-27-2010, 07:03 PM
Dieselkiss's Avatar
Dieselkiss Dieselkiss is offline
Vehicle: 99 Ram 1500
Trim Level: ST - Very Base Model
Color: Red with grey
Rep:48
Dieselkiss is on a distinguished road
I haven't had my '99 very long so I can't speak with a lot of experience. That said, my truck has 186,000 miles on it and the 4spd auto box is incredibly smooth and responsive - even when she's cold.
I've heard after 100,000 you're on borrowed time, but I can't find anything in the history of this vehicle regarding gearbox issues/rebuilds so fingers crossed it stays reliable and smooth.
Old 02-27-2010, 10:36 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
2 transmissions in 250,000 miles
Old 02-27-2010, 10:53 PM
I've had my trans rebuilt once by the dealer at 36,000 miles . I should say they half ass rebuilt it . Then right around 110,00 miles it went up again . I pulled it and had someone go through it and put in all the updates that were available for it . So far so good . No issues worth complaining about . I've said if it goes up again , it's getting a 5 speed .
Old 02-28-2010, 02:46 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
change the fluid and filter at regular intervals, and turn the overdrive off when towing and you'll be okay. Also, if it shifts down constantly when going up hills and all, just turn the overdrive off.
If you do all that...she'll last you a good while.
Now, I don't tow anything with this truck (doesn't have a hitch), nor is there hills in FL...lol But, this tranny takes a beating nearly everyday just from my type of driving, and, she'll still shift crisply every gear (knocks wood). And, if you let it, it'll occasionally chirp 2nd (it does have a shift kit, but still)...haha.
But, this is the original tranny at 149,000 miles.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 02-28-2010, 03:23 AM
zzz zzz is offline
Vehicle: 2000 dodge ram 2500
Color: green
zzz is on a distinguished road
Had my 2500 for 3yrs try took a dump on me around 180thousand miles. I changed the oil every 3000 miles. In them three years i was hard on her, haulen cattle to 1 ton bails. And most was in muddy terrain where i should have been usen a tractor But when the tranny goes make sure that you find a good shop, the one that did mine sucked Been through 5 trannys now, cause the shop never replaced or flused the raditor. If you keep up on maintance and get a good temp gauge she'll do you right, oh and a shift kit.
Old 02-28-2010, 09:23 AM
Rep:1877
The 46RE isn't the best trans Chrysler ever put out and the results on durability are a mixed bag. I've seen the later models do well but the '99's weren't terribly great. I have seen vavle bodies crack under the pressure of shift kits on trucks with big tires and modded engines. If you plan to do any serious wheeling, I'd recommend the manual.
Old 02-28-2010, 09:38 AM
Dieselkiss's Avatar
Rep:48
Ok people....what is a shift kit?
Old 02-28-2010, 04:38 PM
DarkRam01 DarkRam01 is offline
Vehicle: 2001 Dodge Ram Ext Cab
Rep:13
DarkRam01 is on a distinguished road
i have an 01 5.2 with 120k miles and the tranny is actin up, shifts great (sometimes) sometimes have to left off the gas for it to shift 1-2 or 2-3 and also it takes off in 2nd gear sometimes so.... i dunno. still love my truck
Old 02-28-2010, 05:58 PM
I don't plan to do any serious wheeling, just the occational offroad trip, on trails through mud, maybe some hill climbs, and maybe crossing the river now and then. I just want something that will last for a little while at least. Main reason for the truck, is to pull a car trailer with my Trans am for auto x and drag racing events. The trans had the master rebuild kit put in by an ASE certified mechanic about 800 miles ago
