Latest Vendor News |
| Dodge Ram Accessories! |
02-28-2010, 02:32 PM
Vehicle: 2005 Dodge RAM
Trim Level: Lone Star Edition
Color: RED
Rep Power: 0 Rep:15
Code P0404
After filling up the other day my check engine light came on. Nothing seemed different when it did. I went to take it to the dealer and on the way the light went off. Last night while driving home from work it came on again. No change in performance that I can tell. I had the codes read today and it shows P0404 which I see is a EGR Valve. I was looking around alittle and see this might be covered under some federal emission warranty. My Truck is a 2005 RAM 1500 5.7 with 45,691 miles. If not under warranty anyone have an idea of the cost I am looking at.
Thanks for your help.
RamForumz.com | Dodge Ram Forum | Dodge Ram Forums | Dodge Ram Performance | Dodge Ram Accessories | Custom Dodge Ram | Dodge Truck Forum | Ram Truck Forum
02-28-2010, 03:27 PM
Technician On A Mission
If you have the Hemi, you can about bet the valve itself is bad. I'm not sure if the warranty will cover it but it certainly won't hurt to ask. I think the valve runs about $150 (ballpark) for the valve and it's something you can easily change yourself.
02-28-2010, 04:27 PM
Color: RED
Rep Power: 0 Rep:15
Yes it's the Hemi. I am not much of a mechanic so I was thinking of taking it in. What all is involved with changing it out ? Is the 150 just for the part ? or is that an estimate of part and labor at the dealer. One last question, Is it ok to drive for a day or two before I can get it fixed ?
Thanks
02-28-2010, 04:55 PM
Swapping it is a matter of removing a few bolts. If you decide to do it yourself, I'll post a how-to. The ballpark price I mentioned is for the part only and it will be ok to drive for a few days.
02-28-2010, 05:02 PM
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Dont forget to clean the return tube to the intake as well with some Brakeclean....
02-28-2010, 05:08 PM
Color: RED
Rep Power: 0 Rep:15
If you could post a how to that would be great. I went out to look at it. It does not seem like much. A metal tube bolted to it. I am guessing remove the two bolts connecting it to the metal tube and its off. Also what about the check engine light, do I need to go to a auto store to get it reset ?
Thanks for the help guys
02-28-2010, 05:26 PM
02-28-2010, 05:58 PM
Color: RED
Rep Power: 0 Rep:15
Looks simple enough, My one question is, the first step (# Use a diagnostic scan tool to record any DTC's (Diagnostic Trouble Codes). Is this what I did to get P0404 or is this something I need to hook up to the EGR wires.
Thanks
PS does the valve come with the gasket, seals or do I need to purchase them also.
02-28-2010, 09:49 PM
Color: RED
Rep Power: 0 Rep:15
Is this the steel tube connecting to it ? Do I need to take the whole tube off to do this. Also you mentioned brake cleaner, Just squirt it in ?
Sorry for all the questions, and thanks again.
02-28-2010, 10:12 PM
Trim Level: Custom
Yeah, take it off, clean the inside real good, use the little straw that comes with it to squirt it in the tube
