Old 02-28-2010, 05:01 PM
cashman36 cashman36 is offline
cashman36 is on a distinguished road
Default Code P0340 and P0443
2000 Dodge Ram 1500, 5.9L. Since Nov my truck has had three occurrances that it wouldn't start. After being patient for 30 mins or so it would finally start perfectly. Engine would turn over fine, just not start. I'm getting two codes, P0340 and P0443. One being a CAMshaft sensor. None of the autoparts stores around here carry a CAMshaft Sensor. All have a crankshaft sensor. Can you tell me what the issue is? And if I need a CAMshaft sensor, where can I get one?
Old 02-28-2010, 05:08 PM
Rep:1885
The cam sensor is in the distributor on your truck. You may wind up going to the dealership for one if the parts stores can't order one for you. The P0443 indicates a problem with your EVAP purge solenoid, wiring or the PCM.
Old 02-28-2010, 07:07 PM
Thanks Randy. So can I just replace the distributor cap and button, or is the Cam sensor in additon to those items? I'm assuming located inside the cap, but probably under the button.
Thanks,
Jamie
