Old 03-01-2010, 12:56 PM
hauser775's Avatar
hauser775 hauser775 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SLT Laramie
Rep:67
hauser775 will become famous soon enough
Default Lug nuts fell off
So last night I was on my way back to school, and the front passenger side wheel and tire fell off the truck, and all 5 studs where cut flush, and it messed up the rotor pretty good. Not good while doing 60mph. Anyways, I have not touched the wheels or tires on the truck since I bought it in January, which had new tires put on the day before I picked it up. I have had no problems with them at all. I heard that if the lugs are too tight that it can cause too much friction and then the lugs can become loose and the studs snap. Is there any truth behind this?
Old 03-01-2010, 01:08 PM
Kens04's Avatar
Kens04 Kens04 is offline
Vehicle: 2004 Ram QC 4x4 HEMI
Trim Level: SLT OFF ROAD
Rep:48
Kens04 is on a distinguished road
Ive never heard that. If they are overtightened I think the only thing you risk is breaking off the studs when you try and remove them later down the road.
Thats sucks but glad your okay.
Old 03-01-2010, 01:38 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 2014 Ram 1500 Quad
Trim Level: Lone Star
Color: Blue Streak Pearl
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Not as described,,, An over-tightend bolt does not cause any 'friction' after it's been tightened.
You can overtighten and 'stretch' any bolt to the point of failure.
Bolts that have been stretched excessively may not snap if you stop tightening them, but they will be weakend.
In structural steel, bolt torque specifications for each 'lot' of bolts are obtained by the use of a device called a 'skidmore'.
What happened in your case? Not sure,,, might have had a gorilla tightening up the lugs on that one wheel,,,
,,,At one time or another,,,
Any chance someone at school messed with it????
Old 03-01-2010, 02:01 PM
txhemi's Avatar
txhemi txhemi is offline
Vehicle: 2008 Quad Cab 1500 2WD
Trim Level: SLT Lone Star
Color: Mineral Gray
Rep:268
txhemi is a jewel in the roughtxhemi is a jewel in the roughtxhemi is a jewel in the rough
Sorry to hear that! I know your pain from first hand experience though. I had this happen on my 69 GTO. No fun.
Old 03-01-2010, 02:06 PM
DigzDodge07's Avatar
DigzDodge07 DigzDodge07 is offline
Vehicle: 2007 DodgeRam 2500HD4X4
Rep:48
DigzDodge07 is on a distinguished road
At least you held under pressure and came out ok.
Old 03-01-2010, 03:11 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Sorry to hear that, must have been scary. Here's a funny story, a bit raunchy, but funny.
Old 03-01-2010, 03:41 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
Ron wight is so funny only problem with his story is that Mercedes makes a van but party at Ron whites big of F#$%in building
Old 03-01-2010, 04:15 PM
I push the skinny pedal
Rep:3277
Sorry to hear about your troubles. I've never had this happen on a vehicle, but i've lost 2 trailer wheels like that, thank god our 9600lb trailers have 4, or i would've been screwed.
Kurtis
Old 03-01-2010, 04:30 PM
Rep:2642
Tirerack has this to say about tightening your lug nuts
http://www.tirerack.com/wheels/tech/...jsp?techid=107
maybe you should check the rest of your studs, your truck is at least 9 years old, if anyone in the past used a air gun set to higher than 70 pounds, it could have stressed the studs almost to the point of failure. a good tire shop sets the pressure below the specs & hand tightens the rest of the way, a cheater bar should not be used when tightening
Old 03-01-2010, 06:14 PM
ScatPak07's Avatar
Rep:970
Wow well good thing your alright!! Thats gotta be a pain while driving. I would maybe think someone tried stealing them or something and someone caught them in the act so they left em loose. Or someone is jelous of you and tried ruin your ride.
I would look at all your other wheeels to see if any others are loose or overtightend. Well goodluck man! Hope everything goes well!
