Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 03-05-2010, 07:36 PM
gomango0042 gomango0042 is offline
Vehicle: 2004 ran
Trim Level: sport
Color: red
gomango0042 is on a distinguished road
yes i have never checked my fronts have only seen it on rear when i was hooking up my trailer and it is just the outside. my wife told me that when it done it there was a clicking from under the dash. wonder if it is some sort of a bad rely? will check into mine better when it warms up a little.
Old 07-11-2012, 12:58 PM
airassaultram airassaultram is offline
Vehicle: 2006 ram 1500
Color: red / silver
airassaultram is on a distinguished road
Default letter from chrysler
I got a letter in the mail from Chrysler stating that there was a problem with the blinker control system a manufacture defect. I called up my local dodge dealer and they said if I received the letter to show them and if I was experiencing problems pertaining to the defect then they would fix it free of charge. Although I haven't gone in to get it fixed do to me working all the time. Don't know if this will help anyone but I have an 06 ram 1500 4.7 liter. It could be worth checking into.
Old 03-12-2013, 10:18 PM
tmg.cnh.320's Avatar
tmg.cnh.320 tmg.cnh.320 is offline
Vehicle: 2006 Cummins
Color: Gray
tmg.cnh.320 is on a distinguished road
kjtc6-- I had the letter of extended warranty from the chrysler corporation covering the replacement of the multi-function switch about 2 years ago. My blinkers started doing the EXACT same thing yours is doing last friday. I took it in to have the switch replaced. IT DIDN'T FIX THE PROBLEM! I am on a mission to find the problem and post the remedy. If someone already knows how to fix this, PLEASE by all means make it easier on all of us currently and in the future.
Old 03-16-2013, 08:36 PM
Color: Gray
Had a diagnosis done today at a top rated local auto electric shop for the turn-signal issue. They said the problem is actually in the trailer tow wiring harness under the bed and is affecting the rest or the circuitry. Something about a brown and a green wire, the trailer brake/tail light circuit. I was told that if I were to pull the fuse for the trailer light circuit, the problem would go away. I pulled fuse #15 and voila! Now I just have to locate where the wires are actually crossed and better insulate them. I'm just afraid that the problem wires are in the harness located in the frame rail along the side of the tank, requiring removal of the tank.
Old 03-16-2013, 10:58 PM
Color: Gray
Old 03-29-2013, 05:14 PM
Color: Gray
Final diagnosis on the turn-signal issue on my 06 Ram.. The 4-pin trailer electrical connector had corrosion under the weather-tight cap. Go figure!
Old 04-06-2013, 11:42 PM
Wedge775's Avatar
Wedge775 Wedge775 is offline
Vehicle: 2010 Dodge Ram 1500 SportCC
Color: Mang Tango
Wedge775 is on a distinguished road
I have the same problem with my rear lights. Left turn signal flashes all my rear lights. Turn lights on and they work normally. I tried the above, pulling the fuse, but that didn't work.
Old 04-07-2013, 06:48 PM
Wedge775's Avatar
Color: Mang Tango
Got mine fixed, thank goodness. My problem was a set of side shine LED switchback strip I had installed under my headlights. The driver side one was throwing feedback into the parking lights when it was turned on to blink. They looked good on the headlights, but there gone now and my taillights function correctly now.
Old 04-29-2013, 11:16 PM
shadow's Avatar
shadow shadow is offline
Vehicle: 2003 dodge ram 1500
Color: blue
shadow is on a distinguished road
I have an 03 Ram 1500 w/ 5.7 hemi and had the same problem. I found that if I turned on and off the 4 ways or went from low beam to high beam the problem went away. So it would suffice to say the multi switch needs to be replaced.
Old 06-06-2013, 03:46 PM
mudrunnr mudrunnr is offline
Vehicle: 2006 Dodge Ram 1500
Trim Level: TRX 4
mudrunnr is on a distinguished road
I wish I would have seen these posts earlier. I posted a thread earlier today about the same thing going on with my truck. Definately some things to look into on my truck. It was suggested to me to check the tail light circuit boards as the poster had a hairline crack in one of his allowing water to leak into it and causing problems. I will repost with what I find on my truck.
