1998 ram shackle rust with pics - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-01-2010, 06:43 PM
jeepthing07 jeepthing07 is offline
jeepthing07 is on a distinguished road
Default 1998 ram shackle rust with pics
I just bought this 1998 Dodge ram 1500 2wd 360 V8. It's in pretty good shape not much rust under it at all sheet metals all good but then this happened...
WTF? Anyone else have this problem? I haven't had this truck 2 weeks.... this better be the last stupid problem with this truck or im trading it off on a Toyota
Old 03-01-2010, 06:46 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
I can see why your frustrated. It could be worse i guess.Never had that happen. Had a 99 and it was good underneath.
Old 03-01-2010, 06:47 PM
And this is the other side... its about to go to you can see a hairline crack starting to form in it.
Old 03-01-2010, 06:49 PM
Did you know the former owner ? Wonder if it was used for putting a boat in the water . If so even your Toyota couldn't resist that .
Old 03-01-2010, 06:58 PM
bones64's Avatar
Rep:659
Looks like that plate that sourounds the shackle is a good place for water to stay. Good point Tom about the boat...........Sounds logical to me.
Old 03-01-2010, 07:07 PM
bought the truck locally they never pulled a boat..... I live in Illinois they use salt on the roads in the winter so some rust is to be expected. But the main areas I looked at like rockers and floor boards and frame all looked good for it being a 1998. Whatever steel they used to make the shackles out of is JUNK! I just ordered some replacements from mopar for $64 i didnt have another choice i dont want to lower it with aftermarket shackles.
Old 03-01-2010, 07:14 PM
bones64's Avatar
Rep:659
Is that each or a pair.............Good to know that everything else underneath is good. I know about salt. Being in Ontario, Canada they use a wack of it.
Old 03-01-2010, 07:44 PM
It was for the pair shipped from a discount mopar parts place.... I think it was like $26 each when from a non discount dealer it was $40.95 each
Old 03-25-2010, 10:47 PM
gregor413 gregor413 is offline
Vehicle: 1997 Dodge Ram 1500 Club Cab
Trim Level: Sport 4x4
Rep:16
gregor413 is on a distinguished road
I have to replace mine in my 97' too. I was just searching for a spot to buy stock hight shacles too. Seems everyplace has lowering and lift shackles but a slim few have stock hight.
Give me some tools, beer and something to fix and I will show you a happy man.
Old 03-28-2010, 01:44 PM
BigLoo BigLoo is offline
BigLoo is on a distinguished road
[QUOTE=jeepthing07;165599]Whatever steel they used to make the shackles out of is JUNK! [QUOTE]
No, it's not junk, it's STEEL. Even your vaunted Toyota uses the same STEEL, and when esposed to salt and moisture, would rust jus t as badly...because it's STEEL. Let this be a lesson for you, when buying a truck in a place known for rust, look at ALL the STEEL, not just the pretty parts. That shackle was going LONG before you got it, and you should have seen it.
