Old 03-01-2010, 11:36 PM
DaKid's Avatar
DaKid DaKid is offline
Vehicle: 2000 Ram
Color: Dark Garnet Red Pearl Coat
DaKid is on a distinguished road
Default 89 Octane
So today I put pretty much an entire tank of 89 octane in my
truck. I mistakenly put it in because itwas the same
price. I don't have a chip/programmer, the engine is completely stock. I believe octane rating is a fuels resistence
to premature combustion. I feel like my engine is idling a little bit rougher. Could this be true? And is this hurting my engine?
Thanks guys
Old 03-02-2010, 12:03 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
i dont know if this is true but i heard that on some engines you should run mid grade gas in them once in awhile
Old 03-02-2010, 12:09 AM
I push the skinny pedal
Rep:3277
You should be fine with 89 if you're running a stock engine. Mostly you need to run higher octane if you've got a programmer. If you're worried about it, just fill up at a half tank with 91 then go back to your usual octane rating.
Kurtis
Old 03-02-2010, 01:00 AM
DaKid's Avatar
Vehicle: 2000 Ram
Thanks guys. I wasnt TOO worried, just something I had been wondering about also. Hopefully a Superchips is in my near future, and then I can fill up with 92 and be tearing up the road!
Old 03-02-2010, 01:20 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I run 89 all the time
Old 03-02-2010, 01:40 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
all 89 octane is, is 87 and 91/2/3 mixed.
I work at a BP station, and thats how we do it...it just mixes right at the pump, and into your tank.
So, no, it won't hurt anything...and, if you put half a tank of 93 in there...you'd end up with something like 91 octane or something.
And, your right, the higher the octane, the less prone to pinging (preignition). Also will make it run cooler as well.
Also...not really relavent here, but, if you run leaded gasoline in a car (110 octane CAM2 from sunoco)...and you put half a tank of that, and half a tank of unleaded 93...the leaded and unleaded properties actually mix and you end up with an octane higher then 110. Crazy stuff...but, can save you money and help with performance.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 03-02-2010, 02:43 AM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Yeah you'll be fine. I run 92 right now. Stage 2 jet module. Wish I had superchips! You will sure as hell be ripping it up man!
Old 03-02-2010, 07:51 AM
Dieselkiss's Avatar
Dieselkiss Dieselkiss is offline
Vehicle: 99 Ram 1500
Trim Level: ST - Very Base Model
Color: Red with grey
Rep:48
Dieselkiss is on a distinguished road
As people are answering fuel questions I have one:
I run a '99 318 (Completely stock) with 186,000 miles. I run the cheapest grade of fuel so far and stick in some fuel system cleaner every so often.
Other than servicing her regularly should I do anything else? Should I run higher octane every now and then and is the fuel system cleaner stuff ok or will it perish seals and such on an older truck?
Old 03-02-2010, 04:29 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
I usually run 87 in mine with Superchips set on economy. No problems, and most of my trips are way less than 5 miles. I'm pretty sure the manual doesn't recommend anything higher unless you are having problems. I do run some Seafoam or Lucas through every 3-5K miles. Just don't overdo it.
Old 03-02-2010, 05:59 PM
Your fine .
