2003 ram tires & check engine light, air bag light on - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 03-02-2010, 01:04 AM
morera morera is offline
morera is on a distinguished road
Default 2003 ram tires & check engine light, air bag light on
2003 Ram 6 cyl 2 wheel drive, 4 door, put a 3 inch front wheel level kit and biggest Kuhmo tires i could fit on stock 17 inch wheels, truck vibrates bad on level surface when slowing down or when i apply brakes, less than 10k on new brakes, between 15mph and 30mph vibration is heavy, if road is not leveled, there is no vibration at all, no vibration at high speed either, l have less than 6k on new tires, i dont feel vibration on wheel or on brake pedal check engine light on, what is code C ? also dealer advised to replace seat belt driver side to get rid of air bag light, replaced belt but light still on thank you
Old 03-03-2010, 11:35 AM
LYC79's Avatar
LYC79 LYC79 is offline
Trim Level: SXT CRD 2.0 / 2.8
Rep:426
Sorry I don't have answers for you but I'm sure that someone with better knowledge than me will chime in soon.
But I see you're new so welcome! please don't forget to go in the Newbie Checkin and introduce yourself when you get a chance.
Old 03-03-2010, 08:36 PM
Zekery360 Zekery360 is offline
Vehicle: 2002 Dodge Ram
Color: Bright Red
Zekery360 is on a distinguished road
What exactly is the size of the tires you put on? That would be a big help. If the tires are ginormous monster truck worthy beasts, it is possible to overwork the brakes. Also, key dance for the code, and let us know that. Between those two things, I think all the vehicle-savvy people on here should be able to collectively figure it out for you! Let us know what you find.
Old 12-27-2010, 01:42 AM
che65velle che65velle is offline
Vehicle: 2003 Dodge Ram 1500
Color: BLUE
che65velle is on a distinguished road
For the air bag light, sometimes the clock spring behind ur steering wheel can brake. If its broken, that air bag light can come on. For the vibration of the truck, ur rotors might be warped either because of the new tires or because they were heated up and u ran through water. Because of the bigger tires you can expect these type of issues to arise. But those things u can check without having to spend lots of money at what the worthless dealership will advise u to do.
Old 12-27-2010, 02:10 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
how are your u-joints? when they go bad, vibrations will occur during different speeds and driving conditions.
