Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 03-03-2010, 06:59 PM
Zekery360 Zekery360 is offline
Vehicle: 2002 Dodge Ram
Color: Bright Red
Zekery360 is on a distinguished road
I went to Tirerack.com for my research. In the end, I don't have the money for some nice BFG's, so I am sticking to OEM anyway. But that would be my suggestion.
Old 03-03-2010, 08:31 PM
ScatPak07's Avatar
Rep:970
Yea the BFGs are really nice, they add to the look of the truck. I have seen so many truck with them around Oakville, not original anymore haha
Old 03-19-2010, 11:14 PM
monteskr monteskr is offline
monteskr is on a distinguished road
I had to step in and answer this one so you don't waste a lot of time like I did. I have had my 02' Ram for almost six years. I had vibration problems just like your situation. I can't tell you how many times I rotated tires, got them balanced, checked and re-checked. The problem turned out to be my rear brakes. The caliper bolt slide would was contaminated and literally could barely slide. The pressure of not being able to move freely would put just enough pressure on the brakes at an uneven angle that it would cause a vibration, usually around 65 mph. When I did the brakes I replaced the pin, shaft and boot. I made sure I lubed it good and that everything moved freely before I put it back together. Vibration problem is now gone. Hope this helps you narrow down your problem.
