Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - News Desk > MOPAR NATION - Dodge Ram Club Regional Chapters! > North East
North East CT, ME, MA, NH, NJ, NY, RI, VT
Old 03-02-2010, 09:45 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Exclamation 2001 Dodge Ram 1500 5.2L Cat Problem
Had dual exhaust put on by Lou's Exhaust in New Hampshire. Great Sound but plenty of problems that I never had before. 420 Reading with engine light on. New Cats, O2 Sensors, on cold mornings truck will stall and I have to warm up for 10-15 minutes and rev it up. I use the high grade gas. Any ideas on why truck stalls and low rpm when starting?
Old 03-02-2010, 10:15 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Not sure what that code is, but welcome to the forum anyways. Might want to go the the user CP and fill out your profile. Then all the data for your truck will come up in the upper right corner with every post. Someone will chime in soon.
Old 03-03-2010, 12:14 AM
Might try cleaning the throttle body bore and plate . Start with that and see what it does for ya . Let us know how you make out .
Old 05-18-2010, 11:22 PM
ramHD ramHD is offline
Vehicle: 2006 Ram 2500
ramHD is on a distinguished road
PO420? that should be a cat converter efficiency code. your converter is not working, or there is an issue with the downstream O2 sensor. some aftermarket cats just dont cut it as far as being able to store the same amount of O2 as the OE cats do. also I have seen people install the wrong O2 sensor in the down stream (after cat) position. can cause all kind or running and driveability issues. the other weird thing I have seen is a problem with the trans solinoid packs going bad and causing the computer to think the downstream O2 is shorted.
