Need help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 03-03-2010, 07:53 PM
brunswickmariner
Default Need help
Ok I have a 99 quad cab ram 4x4, 318 auto trans, well a couple of weeks ago the check engine light came on, the engine died , the no buss showed on the odometer, took the control box off passenger firewall cleaned up and reinstalled, the trucked worked fine till today, now the check engine light is on the fuel gauge dropped to empty ( actually full ) and pulling from stop not dropping down to low, pulling from second unless manually hauling selector into first, also idling around 1100 rpm now
Any suggestions would be greatly appreciated since its my everyday wheels
Thanks
Old 03-03-2010, 10:21 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
hope someone can help you sorry i can help
Old 03-04-2010, 01:56 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Think the "no buss" means not seeing the computer. Over my head though. Good luck
Old 03-04-2010, 03:42 AM
zzz zzz is offline
Vehicle: 2000 dodge ram 2500
Color: green
zzz is on a distinguished road
I had a ''no bus'' to on my truck. But mine wouldnt even start, couldnt pull any codes. If you can check your codes, autopart stores do them. Read alot about this problem, said to check the camshaft sensor, ADS relay, and fuel relay. This didnt work on mine ecm was fired. Hope that you get it figured out.
