Braking issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 03-03-2010, 09:59 PM
LoKi's Avatar
LoKi LoKi is offline
LoKi is on a distinguished road
Default Braking issue
I have a 97 ram when pressing the brake One second it will be hard as a rock and not wont to stop. Then I can release it and step on it again and it will go to the floor and about put you through the windshield. I have been told the this could be a Master Cylinder or a booster going bad. How can I check this and figure out which one it is?? Thanks for any help.
Jason~
Old 03-03-2010, 10:16 PM
eddie7644 eddie7644 is offline
eddie7644 is on a distinguished road
in my opinion it sounds like a booster is going bad. The way to check is pull the big hose coming from the master to the booster nad see if there is fluid in the bottom of the booster. In that case if there is that would be the booster going bad causing it to suck the fluid in when its not supposed to.
Old 03-04-2010, 02:11 AM
Resident Technician
Rep:1915
Say what? It could be a booster problem but what hose are you talking about? There's no hose from the booster to the master cylinder. How do you propose to look inside the booster to check for fluid in the bottom? Any brake fluid between the master cylinder and booster indicated a leak in the master cylinder.
Old 03-04-2010, 10:04 AM
Kens04's Avatar
Kens04 Kens04 is offline
Vehicle: 2004 Ram QC 4x4 HEMI
Trim Level: SLT OFF ROAD
Rep:48
Kens04 is on a distinguished road
Isnt the big hose a vacume hose, which is the one you would use for seafoam, pull it off and let it suck in the seafoam?? Never worked on a brake booster but how could you check for fluid in it?
