Old 03-04-2010, 12:32 PM
HemiDoug's Avatar
HemiDoug HemiDoug is offline
Vehicle: 2005 Dodge Ram 1500 HEMI 4x4
HemiDoug is on a distinguished road
Cool Will any 6.1 HEMI parts improve 5.7 HEMI
Curious if anyone has swapped any 6.1 HEMI parts to the 5.7 HEMI, I've seen posts about the cam and that's about it, I'm wondering about the rocker arms intake with the TB even the fuel injectors and plug coils. Parts that don't involve tearing the engine down or out that can add performance. Has anyone done anything to this effect with good results?
Old 03-04-2010, 01:24 PM
jkulysses jkulysses is offline
Vehicle: 2007 Ram Quad Cab
Trim Level: 2500 4x4 HEMI
Rep:68
jkulysses will become famous soon enough
I would also like to know about this and how hard is it to put a new cam in these engines? I bet it would be a pretty expensive upgrade for probably fairly small gain but I could be wrong about that.
Old 03-04-2010, 01:59 PM
Rep:1909
With an intake swap I would expect to see top end gains with a loss of low end performance. Not really what you want for a truck. Bigger injectors are pointless if you aren't moving more air into the cylinders. Swapping rockers won't yeild anything either.
Old 03-04-2010, 02:02 PM
Rep:1909
I have yet to see any cams (at least from Mopar) that are compatible with MDS engines. If you're not making mods to the heads and induction system, a cam just isn't enough bang for the buck IMO.
Old 03-04-2010, 02:17 PM
HemiDoug's Avatar
Just thinking that the 6.1 might have a better rocker ratio or maybe a better flowing TB just looking for parts that are already proven that would be simple to swap. Maybe find a complete 6.1 in a scrap yard to pull parts from.
Old 03-04-2010, 05:49 PM
Wonder if you could swap out a 5.7 for a 6.1 ?
Old 03-04-2010, 07:03 PM
Rep:68
What about the 3/4 ton's like mine that don't have MDS would I see any gains from a cam?
Old 03-04-2010, 07:26 PM
HemiDoug's Avatar
As I understand you can swap a aftermarket cam to a MDS Hemi with no drivability issues, I have read of swaps in some of the other "forums"
Old 03-04-2010, 07:54 PM
HemiDoug's Avatar
You would probably have to have a complete donor vehicle for the engine, trans, and ECU and someone with acess to Dodges DRBIII handheld scanner to program the little problems
Old 03-04-2010, 08:26 PM
I push the skinny pedal
Rep:3308
Some parts can be swapped from the 6.1 into the 5.7 with no issues (just some time for the CPU to learn them). A 6.1L camshaft swap will net you approx 20RWHP.
Kurtis
5.7 hemi, 6.1 hemi, performance, power adders
