Rack and pinion problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-04-2010, 01:51 PM
DodgeRR DodgeRR is offline
Vehicle: 2005 Dodge Ram 1500 Hemi
Trim Level: SLT 4x4
Rep:13
DodgeRR is on a distinguished road
Default Rack and pinion problem
The other day when my truck was running, i noticed a yellowish/green fluid slowly drippin under my truck. having no idea what this could be i took it to the stealership. the checked all the fluids and joints etc and found out the rack and pinion was shot and was leaking fluid. the fluid can not be filled and they say its gonna be 1200$ to fix and align it. Anyone else have this problem? this truck has given me more and more headaches the past 2 months. starting to get rediculous
Old 03-04-2010, 02:13 PM
Resident Technician
Rep:1915
Sounds like someone put in the wrong fluid possibly causing the failure.
Old 03-04-2010, 02:46 PM
Trim Level: SLT 4x4
Rep:13
well they say the part is 800$ for a new rack. ive been looking online and can get the part for a couple hundred. anyone ever change one of these before?
Old 03-04-2010, 03:08 PM
Resident Technician
Rep:1915
The $200 one is a reman unit versus a new unit. It's a pretty simple swap that takes about 45 minutes to an hour. You'll also need to flush and fill the p/s system with ATF+4.
Old 03-04-2010, 03:25 PM
Trim Level: SLT 4x4
Rep:13
thanks def gonna look into doing it myself
Old 03-04-2010, 06:47 PM
Not hard to do at all . You will need to get the front end realigned .
Old 03-05-2010, 06:58 AM
Rep:4376
Was wondering that myself, didn't sound right to me, but we did the rack on my ex's Dak, took about an hour, and then we aligned it ourselves, took it to the shop to check it against the machine, and our handywork was well within spec. Good luck!
Old 03-05-2010, 02:47 PM
09bighorn's Avatar
09bighorn 09bighorn is offline
Vehicle: 2009 Dodge Ram Quad Cab
Trim Level: SLT Bighorn
Rep:22
09bighorn is on a distinguished road
Out of all the rack and pinion jobs I have ever done, these are the easiest. The green color might be ultraviolet dye that someone put in to make finding a leak much easier. If you have any mechanical knowledge they are simple. Just get the truck aligned afterwards right away.
tinted, remote start, slightly debadged, full swap to LED's in process, lockpick camera, truxedo deuce, Volant, linex ,more to come, just have to convince wife!
Old 03-06-2010, 12:27 PM
Zekery360 Zekery360 is offline
Vehicle: 2002 Dodge Ram
Color: Bright Red
Zekery360 is on a distinguished road
Don't mean to thread jack, but I also have the same leaky rack issue. So my question is, how would I go about flushing with ATF? And how much would I need to buy to flush it out really good? I am not sure how well my r&r will go, as I would probably have to do it on the ground, but we will see what happens.
Thanks guys!
Old 03-08-2010, 11:46 PM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
My buddies rack and pinion is gone too on his 05 laramie. I dont recall it leaking fluid tho. I ve heard this is a very common problem with rams.
