Which Antifreeze Coolant To Use - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum
Old 03-04-2010, 07:52 PM
Dizzydan02 Dizzydan02 is offline
Gender: Not Specified
Dizzydan02 is on a distinguished road
Default Which Antifreeze Coolant To Use
Hello everyone I just flushed my radiator and of course the dirt that was blocking a hole got flushed out and now my radiator leaks.
If I get this one fixed or buy a new one which antifreeze coolant should I use?
I know alot of people like to use the Mopar HOAT for their 5.7 Hemi's but what about my 5.9 Magnum?
Is Dexcool as bad as people say?
The owners manual doesnt say anything specific to use it just says to use a high quality ethylene glycol-base coolant and not to use plain water or alcohol based products.
Truck Info:
1999 Dodge Ram Quad Cab SLT Laramie
5.9L V-8
Old 03-04-2010, 07:57 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
I am a Prestone guy.
Old 03-04-2010, 09:07 PM
I still use the regular green antifreeze with distilled water as my mixer instead of tap water .
Old 03-05-2010, 12:34 AM
Rep:3347
I'm a Prestone guy as well; but I buy the concentrated and do my own mix for our colder winter (i do a 70/30 mix for winter). Make sure you use the distilled water since the mineral content in tap/well water will build up in the rad.
Old 03-05-2010, 12:39 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
i use prestone because its always on sale at the auto store
Old 03-05-2010, 07:40 AM
rickerred's Avatar
rickerred rickerred is offline
Vehicle: 2011 Sport
Rep:43
rickerred is on a distinguished road
[QUOTE=Dizzydan02;167409]Hello everyone I just flushed my radiator and of course the dirt that was blocking a hole got flushed out and now my radiator leaks.
As stated in your opening statement use ethylene glycol base, and like the folks mentioned above if you are going to mix it your self make sure you use distilled water.
Mods: Garmin GPS, Trifold Tonneau Cover, Molded Mud Flaps, K&N Cold Air, Westin Oval Step Sides, Vent Visors, Bully Dog GT Platinum.
Future Mods: What ever I can sneak by my wife.
Old 03-05-2010, 09:46 AM
MuzzledRooster's Avatar
MuzzledRooster MuzzledRooster is offline
Vehicle: 2006 Ram
Color: Inferno Red
MuzzledRooster is on a distinguished road
Here's an interesting article about coolant. http://findarticles.com/p/articles/m...8/ai_n9453107/
Old 03-05-2010, 06:10 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Radiator shop should be able to rod it out and repair it for under $100. Doubt you can get a new one for that. Getting ready to flush mine out, hope your problem isn't contagious!
Old 03-05-2010, 06:34 PM
Rep:2962
IF you do decide to purchase another radiator, there are other things to consider
do you do any towing, do you live when it gets hot, (like the desert), you may want to get a heavy duty radiator, standard radiators used to be 2 core, heavy duty is usually 3 core, much thicker, more coolant capacity
ask a radiator shop if it needs replacing & then ask for suggestions
Old 03-06-2010, 11:04 PM
I dont do any heavy duty towing or anything like that, so I ended up buying a new radiator from O O O O'reilly's. It is a Proliance and it came with a lifetime warranty.
I will still probably take my stock one in to see how much it'll cost to get fixed and sell it to a friend.
Installed the radiator today and filled it up with good old Prestone.
Thanks Alot!
