Old 03-05-2010, 01:12 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Default trans and/or diff cover
Just wondering if anyone has installed an aftermarket trans or diff cover like the Mag-Hytec for the increased fluid capacity and cooling.
I know that lower fluid temps are better but I hardly ever doing any towing so I'm not sure it would benefit me. Are the stock ones sufficient for "normal" and some "spirited" driving every now and then?
http://www.mag-hytec.com/
Old 03-05-2010, 01:17 PM
Rep:1877
I have installed a couple for friends but haven't heard of any real benefits.
Old 03-06-2010, 01:27 AM
Covers are quite expensive . I could see the diff cover benefiting ya if your hauling a trailer or heavy load constantly . Other than that they look cool under there .
Old 03-11-2010, 09:59 AM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
I have the pml deep trans pan, and the T/A performance diff cover/stud girdle, both awesome pieces, the ta cover not only looks awesome but strengthens the diff. Check them out, less than hytec.
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 03-11-2010, 12:02 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
i've got 178+k miles on my 05. I've been wanting to to do either which seems like forever.. one of these days.. I do tow lots and go to the dragstrip as well..so your prolly good whether you do them or don't..
Old 03-15-2010, 01:43 PM
Pride0aries's Avatar
Pride0aries Pride0aries is offline
Vehicle: 2003 Dodge Ram 1500 Quad Cab
Color: Patriot Blue/Silver
Rep:55
Pride0aries will become famous soon enough
Looked at TA cover, can you explain a little how this works/benefits? Going to change my diff fluid and planning on pulling the cover, but don't know much about the stud girdle, etc. Was going to replace the cover anyway with something else if for no other reason than visual and prob turn the old one into a parts tray
I have alloy finned cover for my G Coupe diff (same as VLSD 350Z) which also has plumbing if I ever wanted to put an external diff cooler (not really worth it unless I track the car). That setup makes sense to me because it aids cooling on a diff that runs hot enough to cook its fluids with extended hard driving in hot weather.
I have the OEM "Anti-Spin" limited slip diff on my '03. Pleading ignorance on my truck diff for cover upgrades. Is the point of your upgrade to stiffen the diff?
TIA for any additional info!
2003 RAM 1500 Quad Cab Patriot Blue/Silver
Old 03-15-2010, 01:46 PM
Rep:55
Originally Posted by Toms Blue Ram 1500 View Post
...Other than that they look cool under there .
...and you need another reason why?
